Parasitic battery drain
JimMann
Re: Parasitic battery drain
Postby JimMann » Fri May 05, 2023 5:46 pm
Hi Les, the "battery backed sounder" should only "chirp" at you when you double lock the car, i.e. pressing the lock button on the fob twice in quick succession. Not setting the double lock feature also prevents the car from going into quiescent / sleep mode, which will result in a flat battery very quickly, but not perhaps as quickly as you are finding.
Good find on the XJR to locate the module for that machine. I don't know where the module on the X-150 is physically located, but on the X-100 it's in the wheel arch, under the inner liner.
Why not come along to RGC on Sunday for coffee on May.14.23 and see what the collective thinks?
Jim Mann
Jim Mann
Banchory
