Which rear shocks to buy to replace the originals?
Re: Which rear shocks to buy to replace the originals?
Postby ptjs1 » Sat Dec 03, 2022 11:37 pm
Simon,
There's lots of stuff on other forums about the best approach and order to refit the rear axle. I'll look up some stuff and send it to you.
Postby davidr » Thu Dec 08, 2022 1:28 pm
Simon - I expect that you can't get the driveshafts out of the hubs because they've been Loctited in. This is the standard Jaguar procedure. I have to say that when I take them apart I use copper grease on reassembly and not Loctite. Makes it much easier to get them apart again.
You could try using a puller but often they are in so tight that either it won't work or will break the tool.
My preferred method is an hydraulic press. I thought it worth buying one as I found it very useful for pressing bearings, UJs etc in and out.
We have a detailed article coming up in the magazine on stripping and rebuilding the hubs,bearings and UJs.
David
