Oil Leak - crankshaft rear oil seal
piman
Re: Oil Leak - crankshaft rear oil seal
Postby piman » Thu Mar 17, 2022 8:54 am
Hello Peter,
gaskets shouldn't need a sealer as well, that is the theory. I use Hylomar on one face basically to keep the gasket in the right position. (Some like the breather gasket will not move, but sump gaskets are a different case.)
peterheywood52573
Postby peterheywood52573 » Mon May 02, 2022 4:02 pm
I am looking for reassurance that the rope seal is not gripping the crankshaft too tightly. It is about a month since the crank was fitted and it still requires a spanner to turn it. I would guess around 20Nm.
Peter
