Fault code C2302 - Levelling plausibility error
Moderators:Popsjag, J44EAG
laxexquis288
Re: Fault code C2302 - Levelling plausibility error
Postby laxexquis288 » Tue Aug 20, 2019 12:30 am
jagmar, I can send you the instructions that Irishjag sent me. Just let me know how to get them to you - email address etc.?
iRS,
I have a 2005 XJR here in the States. It currently has the exact same problem as yours did, it rises way to high in the rear, not the front, and we get a C2302 plausibility error.
We've replaced the valve block and tried swapping out another control module, but it is still the same. What exactly was the fix for you?
iRS
Postby iRS » Thu Aug 22, 2019 8:34 pm
Hi there, the initial cause of the problems was a seized height sensor. Other problems followed on from that mostly caused by me. At some point later I had a rear one seize, but that was fixed with far less drama.
Roger S
Aberdeenshire
Early E
X350 - 2005 Super V8
1962 MGB
