Had the ATF and filter changed, and the plugs for my supplied new NGKs. He checked the brake fluid for hydroscopics (what check is this?) and said system didn't need flush out and refill. Also had the top and bottom ARB joints / rubbers done (joints complete I believe since if they're dropped they might as well be changed not just the rubbers?) All of that and a fresh MOT for £700 inc VAT. Not too bad in today's prices from someone who's been around in the Jaguar scene for just a few years
Given the result above had the driver's door ratchet strap replaced -- apparently welding's needed. Had a look at what was removed. The fracture is on each of the right angle fixing brackets either side. Those brackets are made of that horrid un-repairable metal mix (whatever it's name is)
Course, had to put the pedal to the metal -- although it's only 240bhp and done 121k it still was as impressive as my Passat that I've had tuned to 232bhp (on dyno) given that it's carrying around a whole lot more weight. Is it worth getting a re-map on these? Is it even possible?
After 10 years of Germany's characterless finest as a daily -- looking forward to long term with this X308 -- well at least until I judge I'm just too geriatric and not safe to be on the road
