Jaguar F Type TSB's
DougX
Jaguar F Type TSB's
Postby DougX » Sat Sep 07, 2024 3:33 pm
Does anyone know how to access all the Jaguar Technical Service Bulletins (TSB's) for the F-Type?
drjohnehunt100
Re: Jaguar F Type TSB's
Postby drjohnehunt100 » Thu Sep 12, 2024 3:45 pm
Is this the sort of thing you are looking for
https://www.jaguarforums.com/forum/tsb_recall/tsbs
John
DougX
Postby DougX » Thu Sep 12, 2024 4:24 pm
Thanks for this. However, I think this is an American TSB. I was looking for the U.K. TSB’s. Particularly the TSB relating to the exhaust.
Postby mike020150 » Fri Sep 13, 2024 10:37 am
I don't think you will find he TSB of much help. Here is the Jaguar wording about the exhaust reprogramming, "The vehicle pass by noise level of certain vehicles may not conform to UN-ECE R51.02. Special drive programs are held between ignition cycles and the vehicle does not always default to Standard drive program on start-up." Mike.
DougX
Postby DougX » Fri Sep 13, 2024 11:12 am
Hi Mike, are you saying that the car is ‘stuck’ in the non-sport mode? The Dynamic mode does not operate as it once did, with the ‘popping and banging’ it did when it came out of the factory? I have confirmed the activators operate as they should.
Postby mike020150 » Sat Sep 14, 2024 10:17 am
What the bulletin appears to say is that by not defaulting to the 'quiet' setting when the ignition is switched off, when restarted, cars would fail to comply with noise legislation standards. Consequently, the software update corrects that situation. There are no references in the bulletin to any other changes made to the pattern of exhaust noise. Mike.
