Engine oil
What engine oil do I need for my 1998 xk8. Also is this fully synthetic
Dave Eynon
Re: Engine oil
Hi, the Vehicle Care Handbook page 24 provides information on a range of oils that can be used in this car. If you go to the OPIE Oils website (opieoils.co.uk) and put in your car reg they will offer you a variety of oils that you can choose from. The 10W-40 viscosity will cover the ambient temperature range of -5 to + 50'C according to the handbook. The other requirement is the oil meets the minimum specification of API SH / ACEA A2 which they all seem to exceed. If you want an oil for lower than -5 'C temperatures then a 5W-30 oil will be needed but that will need to be fully synthetic ACEA A3.
Hope this helps.
Hope this helps.
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Re: Engine oil
Linda,
I've always run in 5w-30 in my Jaguar 4.0 & 4.2 V8 engines. Either C3 or an LL variant.
Re: Engine oil
Thanks Paul.
Re: Engine oil
Linda,
I have the same problem with what oil to chose. On page 24 of the handbook my car which is a 1996 coupe shows 15W-40 AP1SH/ACEA A2
That covers you between temperatures of -10C to +20C
It doesnt say semi synthetic or other type
The next Oil that could be used is 5W-40 or 10W 40 which covers you between -20C to + 50C with the same specification.
Can someone clarify what oil and make is the best way forward.
Re: Engine oil
alsjaguar,
As you can imagine you'll get a variety of answers from people on both make, type and weight.
My strong suggestion is, if you're UK-based use a 5w30 synthetic from a reputable brand such as Castrol, change it every 10k max miles or every year, whichever comes soonest and your engine will be fine.
Re: Engine oil
David Marks always put 5W30 in my 2001 4.0L (Shell Helix Ultra Professional AF 5W30 the last couple of times).
2001 XK8 4.0 Coupe in Quartz
Re: Engine oil
Yes 5w-30 is the way to go.
Always used that in my X308.
Changed every year regardless of milage along with a new Jaguar oil filter.
Take care.
Take care.
