Both my Driver and Passenger heated seats have stopped working , Display still shows they are on but no heat comes through
Any ideas on what to check for issue
Thanks in advance
2007 Jaguar xk Heated seats not working
Re: 2007 Jaguar xk Heated seats not working
Have you lost any other seat functions? Have you checked the fuses? The seat functions are generally powered through the fuse box located in the passenger footwell, so I'd suggest starting there. Mike.
leelane588
Hi Mike
Thanks for response, no all seat functions work as should, it is only the heat function that has stopped in both
Hi, check the connector beneath the seat as they can come loose, happened on my XF. Bit odd if both have though..
Also, they will automatically shut off if the in car temp is high, though unlikely at this time of year. Lastly, I wonder if there is a separate fuse just for the heating element, but you would need to check handbook to see if that is the case.
XF Sportbrake 2020 / XK8 1998
leelane588
Thank you
Will have a look over weekend
Appreciate the response
