2007 jaguar xk ariel sticking
leelane588
Postby leelane588 » Wed Dec 20, 2023 10:23 am
Hello
My 2007 jaguar xk ariel is sticking at points , it makes it up and down but sticks , motor working but just seems stuck
Anything I can do to free it up
Thank you
JimMann
Re: 2007 jaguar xk ariel sticking
Postby JimMann » Wed Dec 20, 2023 10:29 am
Over time the outside surfaces of the aerial become "sticky" with road detritus and this causes the erratic motion. With the aerial fully up, use a mild metal cleaner to gently clean the outer surfaces and then once you have wiped that off, cover with a fine film of wax, same as you would use on the paintwork. Buff that off and try the operation. If still sticky, then place a "very" small amount of fine grease - Molykote or similar - on your fingertips and massage that in to the surface of the aerial, especially around the section changes and then wipe clean with a lint free cloth or paper towel. Try the operation and it should be fine. Repeat annually as a minimum.
Jim
Jim Mann
Banchory
leelane588
Postby leelane588 » Wed Dec 20, 2023 11:59 am
Thank you
Will give it a try
dyrham663
Postby dyrham663 » Sat Dec 23, 2023 3:30 pm
Sprayed mine with WD40 silicon spray. Has worked fine after that so far.
Steve
XK (150) 2006, F Pace Chequered Flag Petrol 2019
Users browsing this forum: No registered users and 13 guests
