J box and sport mode button XKR 2003.
Manual gear selection on J box selector and sport button work for about 20 minutes driving then light on sport button goes off and manual gears can no longer be selected when moving over from auto. Any ideas on problem please?
andrew.graham97934
Re: J box and sport mode button XKR 2003.
I have a similar problem, intermittently .
From what I have read it can be caused by implausible signals being sent from the linear switch in the gear selector.
I have yet to investigate myself. Apparently the switch can be opened up with care, and the tracks cleaned up.
But I stress I haven't done this yet myself, so anybody who has and can offer advice, I too would be interested.
You might like to look at this topic where I took out the linear switch on my 2001 XKR and cleaned it up. Ignore the first 2 pages of posts as I worked through some other problems
viewtopic.php?f=63&t=14725&start=30&sid ... db2a7f3545
Are you getting any fault lights on dash, eg gearbox fault? The other area that causes problems is the rotary switch on the gearbox itself.
XF Sportbrake 2020 / XK8 1998
Not happy with what I was thinking
Edited out for a re-think
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
On reflection I think if it’s the rotary switch the gearbox goes into failsafe mode and locks in gear 3. So the linear switch more likely culprit.
