Any idea what this is for
Mini
Postby Mini » Wed Apr 12, 2023 10:01 am
I opened up the plenum under the wipers on my 4 litre facelift 1994 and found these two cable with connectors on the end but unplugged. Anyone have any idea what that circuit is for ?
thanks
PaulGover
Re: Any idea what this is for
Postby PaulGover » Thu Apr 13, 2023 11:29 am
That looks like one end of an in-line fuse.
What colour is the cable? It's not clear from the picture. Cable colours are a BSI standard, so provided it's manufacturer-installed, you can work out what circuit from the colour. For example, blue cables (with various stripes) are lighting. Solid black cables are earth.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
Mini
Postby Mini » Thu Apr 13, 2023 11:54 am
One side of the connector has a black and red colour. The other side looks black and black.
I attach a better photo.
JimMann
Postby JimMann » Thu Apr 13, 2023 1:55 pm
Possibly the feed for an after market alarm system, now disabled?
Jim
Jim Mann
Banchory
Mini
Postby Mini » Thu Apr 13, 2023 2:00 pm
So not standard ? Interestingly you can see its got a Jaguar label on it which is why I thought it might have been standard build.
SimonR
Postby SimonR » Thu Apr 13, 2023 5:52 pm
If it's original Jaguar wiring then I wonder if it could be for heated washer jets which I believe the S had in some markets?
PaulGover
Postby PaulGover » Fri Apr 14, 2023 9:05 am
According to a web site, red is for "Side, tail and instrument lighting; number plate illumination". There'd normally be a second colour to identify which - otherwise solid red tends to mean "old style red&black power cable" and nothing particularly automotive, so probably aftermarket or home-made. That means you probably will be reduced to trying to work out where it goes....
I used to have a couple of spreadsheets listing all the BS 7(a) standard colour codes by colour or function; if I can find them, I'll upload them.
2021 I-Pace SE
