Pink or yellow coolant?
fungus221
Postby fungus221 » Sun Nov 20, 2022 11:48 am
Which is it pink or yellow
Many moons ago I bought some coolant for my XK8. Researched it checked what was in there and pink was the one to get.
So ordered some jaguar stuff of the right part number/ code from somewhere (SNG or British parts not sure) to keep in stock . It came in jaguar bottles sealed so didn't open as I was not going to use it yet, right numbers so I thought all was correct. Got it out the other day to do a coolant change. And it's yellow not pink as expected πŸ˜•
Question is. What is right. I thought I had sorted it long ago , but not so sure nowπŸ€”πŸ€”πŸ€”
Don't put off till tomorrow what you can do today.
if you like doing it today you can do it again tomorrow,
Jaguar day at stourhead house and gardens
My youtube channel for XK8 video's and More
Andy P
Re: Pink or yellow coolant?
Postby Andy P » Sun Nov 20, 2022 2:36 pm
Hi fungus221.
I have a sticker by the coolant reservoir with the coolant type on it.
Not sure if the XK8 has one.
Also have this info on XK8 coolant taken from Technical Support and Communications Jaguar Cars Limited Publication Part No. JJM 10 34 99/40.
https://drive.google.com/file/d/1xqmCqR ... share_link
Hope that helps.
Take care.
Andy :D
fungus221
Postby fungus221 » Sun Nov 20, 2022 3:24 pm
Yes I have the same. So that's what I got, I thought.
Suppose you could say the coolant in my XK8 is orange.. I'll have to find some one with pink coolant to compare. But the yellow stuff just seems odd.
Andy P
Postby Andy P » Sun Nov 20, 2022 4:32 pm
Hi fungus221,
The WSS-M97B44-D number relates to the Ford coolant they used which is an OAT coolant.
So any coolant which meets OAT specs should be ok.
This is the coolant I use.
WSS-M97B44-D
I have used this for several years now with no problems.
Hope that helps.
fungus221
Postby fungus221 » Mon Nov 21, 2022 10:29 am
That looks good AJP.
I'll get some of that and see if it's the same as what's in there now.
Thanks all for your help 😊
Still wandering where the yellow stuff comes in with jaguars?
