Ford parts?
robertwilsher67886
Well…. That was a surprise…I’ve been replacing the discs and pads on my STR and noticed the word “Ford” stamped on the metal panels in the front wheel arch…. Are there many Ford parts on a Jaguar S Type?…… (I had heard that the X Type is built on a Mondeo wheel base)
Re: Ford parts?
Yes, while Jaguar was under Ford ownership (forget exact years), lots of parts were shared, the switchgear from my XK8 shares several parts with Fords of same era. Useful to know when buying parts!
XF Sportbrake 2020 / XK8 1998
Re: Ford parts?
The ignition key is ford, and I once had a problem with the wiper motor which I changed and while I was at it I removed the linkage to service it and that was a Ford part, If I'm not mistaken from the Ford Lincoln USA.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
robertwilsher67886
Re: Ford parts?
Yes, I’ve heard that the S Type is built on Lincoln designs
TheColonel
Re: Ford parts?
I recently checked my 2001 S type air filter, and the inside of the housing box was stamped Ford.
Michael
Michael
