HIF44 conversion
rick.potter1777
HIF44 conversion
Postby rick.potter1777 » Sun Mar 28, 2021 9:22 am
Dear forum, has anyone fitted this conversion offered by SU? If so, can I ask what you did about an air filter arrangement (since the HD6 plenum doesn’t fit the HIF44’s).
Regards to all
rick.potter1777
Re: HIF44 conversion
Postby rick.potter1777 » Sun Mar 28, 2021 9:26 am
Sorry, I meant to add, HIF 44 conversion on a 3.4l Mk2.
piman
Postby piman » Sun Mar 28, 2021 9:49 am
Hello Rick,
I have a similar problem coming up as I intend fitting HS 8 carburettors to my car. I intend to modify the original air intake from the air cleaner to match the new carburettors, it doesn't look too difficult. I have the equipment to do so but shouldn't be too expensive to farm out if any welding and machining is required, or make up a slim adapter plate? Depends on your facilities?
rick.potter1777
Postby rick.potter1777 » Mon Mar 29, 2021 9:25 pm
Hi Alec,
Thank you for responding. From what I can see it would require a good deal of modification to the standard plenum to accommodate the additional width between the HIF44 mounting bolts versus HD6’s. For me I see two options - either going to pancake filters or using the plenum from a 420. I know the latter option works but would mean adopting the associated cylindrical air filter housing which I am keen to avoid. I assume the HIF44 conversion is not a popular one!
Regards to all
Rick
piman
Postby piman » Tue Mar 30, 2021 9:25 am
Hello Rick,
I am not familiar with newer S.U.'s but thought the pitch of the carburettors would be the same, assuming using the original inlet manifold?
My basic idea for an adapter plate would be a piece of 8mm thick aluminium, attached with countersunk screws to the air inlet casting, with studs fitted to the plate to pick up on the carburettor flanges. Alternatively and probably better is to weld that plate to the inlet casting?
I'm not familiar with the 420 set up so cannot comment
Personally I don't like pancake filters as I believe they are not very effective and restictive also.
rick.potter1777
Postby rick.potter1777 » Tue Mar 30, 2021 12:07 pm
Thank you Alec; I think I’ll give your suggestion a go.
Best wishes
Rick
rick.potter1777
Postby rick.potter1777 » Sat Apr 10, 2021 8:17 pm
Thanks for the suggestion Alec - adaptor plate finished and now fitted!
Best wishes
Rick
piman
Postby piman » Sun Apr 11, 2021 7:34 am
Hello Rick,
good to see and something i shall do for my car when I get to that stage. Still at the body welding stage at the moment.
Thanks for the update.
