timing belt
rsims193141
does my 92 4L AJ6 engine,have a timing belt or chain,and will it need replacing,or do they really last forever
Re: timing belt
Hi - your car has a timing chain and not a belt. Changing it is not a routine maintenance job like a belt would be.
Having said that, it is known for the timing chains to stretch and throw the valve timing out and the tensioners can get a bit noisy.
Re: timing belt
I actually had a chain snap on my 92 AJ6 (not a pleasant sight).
Nick
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
Re: timing belt
AFAIR on the 4.2 XK engine the guidance was if you ever take the camshaft timing apart, replace the chain as it's so cheap.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
2021 I-Pace SE
