2009 5 litre XK Convertible 97000 miles
I've been looking at the above car. My current 1997 XK8 Coupe is very low mileage but I'm aware of both the Nikasil and timing chain/tensioner issues. Can anyone advise if there are similar issues with this model, especially with this mileage.
Re: 2009 5 litre KK Convertible 97000 miles
Noticed title gives KK when I meant XK!
(Corrected by Moderator MK)
Re: 2009 5 litre XK Convertible 97000 miles
No such issues on the nikasil or timing chains. Water pumps have been troublesome in some cars though.
Thinking about the early XK8s, there is a touch of 'deja vu' about this question and its answer!
Some early 5 litre V8s have suffered from timing chain stretch which throws out the valve timing and eventually can cause the MIL lamp to shine its warning about emissions. This can happen after about 50,000 miles. Jaguar seems to have realised it had an impending issue because the chain size (& sprockets) were altered (from 6.6mm pitch to 8.0mm), along with a new chain supplier. Chain guides and tensioners were also changed but not all at the same time. By the time the run-out XK models were produced (2014), any issues appear to have been solved by this combination of changes and that chain set-up ran through to the F-Type and later V8s, which don't seem to have experienced any problems in this area.
A separate but related problem is removal of the direct injectors from the cylinder head, something which is necessary for work in this area. The Jaguar approved removal tool does not work particularly well and as a result, it can become necessary to destroy the injectors to get them out of the head. Injectors are not cheap (more than £200 each) so the costs of a chain upgrade can begin to snowball. Beware any 5 litre V8 car which shows service history evidence of camshaft retiming without the accompanying costs of new chains etc. Unscrupulous owners have been known to have cams retimed to turn off the MIL lamp and then to sell these cars to unsuspecting buyers.
Mike.
Thank you for the advice given, much appreciated. Does this mean that a late 2009 model 4.2l could be a better buy than an early 5l?
Certainly, the 4.2 litre cars have a proven track record for reliability. Set against that, the 5 litre cars go and handle better with improved trim materials and only some 5 litres show signs of timing chain stretch. It probably depends on how they have been driven. Rather like life, buying any second hand car can be a bit of a gamble! Mike.
alanhulme971
Does anyone know the rough cost of replacing the timing chains, tensioners etc. with the improved parts i.e. has anyone actually had this done?
According to one specialist I have spoken with about this issue, the costs are very variable largely dependent upon the injector issue discussed above. The costs could start around £2k and then easily spiral upwards towards £3K/£4K. Mike.
alanhulme971
Thanks. Was looking at an XK or XKR but prices of early F Types coming into range so considering early F Type but V6/V8 have same timing chain components (a la 5.0 XK & XKR) up to F Type VIN ending K06170 according to Sir Ralf Speth's office at JLR.
