Horn vs steering column
colinM
Postby colinM » Wed Sep 18, 2019 5:37 pm
Some months ago I replaced the upper & lower bushes in the steering column on my 1962 Mk2 - I've only just realised that the horn no longer works. There is max resistance between the wire on the horn push and the boss so I'm guessing the connection is broken at the ring at the lower end of the column. Question is, has the column got to come apart again to sort this or can something be done with it all in situ? It's difficult to see the fitment on the column and backbreaking to get to it.
If I take the column apart, is there a trick to making sure the connection goes back in place correctly?
1962 Jaguar 3.4 Mk2 road car
1962 Jaguar 3.8 FIA E-type racing car
1964 Jaguar 3.8 S-type racing car
2002 Jensen 4.6 S-V8 (the last ever)
piman
Re: Horn vs steering column
Postby piman » Thu Sep 19, 2019 1:21 pm
Hello Mr Breeze,
I seem to remember there is a conducting ring and a bush at the bottom of the column, I would have a look there first as it may have been disturbed?
