Solar powered trickle charger
Moderators:Popsjag, J44EAG
geeegs
Postby geeegs » Fri Jul 19, 2019 7:33 pm
Would this be OK to use with my X350? Or would it mess up with the electronics?
AA 5060114614185 Solar-Powered Car Battery Charger, Black https://www.amazon.co.uk/dp/B00AC1LLQY/ ... mDbSNFAABD
04 XJ 3.5 SE Midnight Black | 04 S-Type 2.7d Sport Ultraviolet Blue
Re: Solar powered trickle charger
Postby J44EAG » Fri Jul 19, 2019 8:32 pm
In my own opinion, the cell is much like many others on the market and will help keep up battery terminal voltage. That said, I`d recommend that you frequently check battery voltage to ensure the cell does not exceed 14.4v if your battery is in a depleted condition.With the aid of a volt meter, you should note that a high 14.4v high reading progressively drops as your battery voltage rises to an ideal figure of 12.8v .
12.8v battery terminal voltage with the cell disconnected indicates a fully charged battery. 12.4v indicates a partially discharged battery whilst 12.0v or less indicates the battery is in a discharged condition and is unlikely to provide enough grunt to fire fuel injectors or the power train module which controls engine management.
cornershop
Postby cornershop » Sat Jul 20, 2019 7:35 am
I tried the same one but returned it as it was doing nothing to help.
Amazon, for all their tax evasion tactics, have pretty good customer service so you can return it if not satisfied - mine could have just been faulty.
PaulGover
Postby PaulGover » Mon Jul 22, 2019 1:33 pm
I doubt it would cause problems - the spec says maximum 200 mA, 12.7 V. Assuming you only have it connected when the car battery is also connected, the battery will smooth out any problems.
I suspect the XJ's standby current in park mode is more than 200 mA! Certainly my car wouldn't start after 3 weeks - that's 3*24*7 = just over 500 hours, and the battery is no more than 100 Ah, that makes for 200 mA!
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
BrianG
Postby BrianG » Thu Jul 25, 2019 1:35 pm
Paul, FYI the workshop manual quotes less than 30mA standby current - but only once the systems have all shut down after about 45 minutes from being fully dead locked. If you only single lock it this shut down does not happen. I checked mine once and it actually was less than 30mA; I did not think it was going to get as low as 30mA because after about 50 minutes it was still at about 100mA and pulsing higher on occasion. It was interesting to note that, once it did shut down, about every 90 minutes thereafter various processors seemed to wake up and do stuff, causing the current to leap up to about 0.5A for about a minute before going back to under 30mA.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
