Indicator - 2002 XJ8 SE
Moderators:robv12, DavidEm
Case
Postby Case » Wed May 01, 2019 7:05 am
Hi all,
I have a 2002 XJ8 SE and would greatly appreciate any advice on the following.
The front nearside direction indicator has stopped working and I have checked the existing bulb which is good and tried a new replacement but it is still is not working. I now want to check the relevant fuse but have been unable from the 'XJ Series Vehicle Care' handbook to trace which one it is. Can anyone assist or offer any other explanation or remedy to fix this, please?
Thank you.
XJ_Driver
Re: Indicator - 2002 XJ8 SE
Postby XJ_Driver » Wed May 01, 2019 7:30 pm
Are the connections in the N/S/F indicator bulb holder good? Is your N/S/R indicator still working? And the repeater on the front wing?
John.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
davidr
Postby davidr » Wed May 01, 2019 8:35 pm
Have you checked the earth? The earth posts are a known weak point
Andy P
Postby Andy P » Thu May 02, 2019 11:25 am
Hello Case and welcome to the forum.
I don't think there is a fuse for the indicators as they are powered by the Body Processor Module (BPM).
Check the ground points as David has suggested,here is an extract from the XJ 2001 electrical guide showing the ground points.
Ground Points XJ 2001
Here is the wiring diagram for the front exterior lights (XJ 2001)
Front Exterior Lights XJ 2001
If you would like the whole Electrical Guide XJ 2001 in PDF just PM me your email address and I will gladly email you a copy.
Good luck on tracking down the problem.
Take care.
Andy :D
Case
Postby Case » Thu May 02, 2019 1:38 pm
Thank you John, David & Andy.
It is only the front nearside indicator that is not working; all others are okay. Connections on the bulb holder all seem clean too. Thanks for the advice on the fuse & checking the earth points & the diagram supplied will help to check this out. Will post an update when hopefully sorted.
Thanks again.
Alan & Andrew (Case)
