hi all any ideas on how to remove the side indicator lens to replace the bulb. and what type of bulb is required.
thanks mike
side indicator lights
Re: side indicator lights
With the orange long wing type on early cars, I`ve used a feeler gauge slipped under one or other of the ends to depress a tang behind the unit. If you can achieve thant, the unit just pulls out from the wing panel. I can`t remember which end you go in from.
The lamp type should be a 501 W5W 12V 5W type. Halfords have them on the rack.
