Connectors on Rear Electronic Module
Seaside_Steve
Postby Seaside_Steve » Sat Jan 12, 2019 6:11 pm
I have purchased a secondhand rear electronic module as it seems from other posts that this is probably the cause of my faulty RH rear indicator. I have started to replace the module. The multiway connectors seem difficult to remove. Has anyone got any tips for removing and replacing these as I don't want to risk damaging any pins in the connectors?
Cubist
Re: Connectors on Rear Electronic Module
Postby Cubist » Sun Jan 13, 2019 6:22 pm
Hi Steve,
I have not checked the connectors on the rear of mine but I did strip the front end down recently to fix a droopy headlight problem. In doing so I came across three types of electrical connector. One had plastic tab and clip locks - lift the clip gently away from the tab to separate these. Another was locked in place using a spring steel clip that locked the two parts of the connector together - tease the steel clip out with snipe nose pliers. The third, on the main headlight loom, has a red tab mounted in the socket to lock the two parts together, push this to the rear of the connector and pull the two have apart - be careful with this type, you can push the complete tab out of the socket and lose it. I also found that a spray of DW40 also helps.
Cheers,
Cubist
The first sign of advancing years - going out to do one thing and coming back having done something else. :?
Seaside_Steve
Postby Seaside_Steve » Mon Jan 14, 2019 10:59 pm
Thanks for the reply, Cubist.
It turned out when I went back to the job yesterday when there was a bit more daylight only one of the connectors was hard to remove. As you suggested you have to push down a tab on each connector to release it.
Cliveheathorn830
Postby Cliveheathorn830 » Fri May 31, 2019 7:40 pm
Hi Seaside Steve
I need the rear light module for my '99 S-Type, could you steer me in the right direction to get hold of a module please
Thanks in advance
Clive
jeff1954
Postby jeff1954 » Sun Sep 29, 2019 3:35 pm
Hi Clive Try Eurojag give them the details of your old unit serial numbers etc and your cars vin number. I got a rear parking sensor module from them some time ago and its still going strong. There details are in the magazine.
Jeff.
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
