Barrs leaks
jagcat12
Barrs leaks
Postby jagcat12 » Mon Oct 20, 2008 11:06 pm
Can anyone tell me the benifit or otherwise of two bottles of this stuff when changing coolant?
Dave
almcl
Bars leaks
Postby almcl » Tue Oct 21, 2008 7:43 am
The instruction to use Bars leaks has been in the manual since XK engine times.
I've used it (for 20+ years) on the aluminium/steel engines and not suffered any leaks (apart from 4 catastrophic kevlar hose failures - you'd think I'd learn quicker!) but some American users think it's the spawn of the devil.
US led bulletin boards are full of people telling each other that it's poison to cooling systems and anyone using it will suffer complete blockage and failure of their radiator. Like much else from that side of the Atlantic, this doesn't quite match UK experience. Although there's no doubt that the lower block area will have quite an amount of the granules present when examined during a block strip down. I am not sure how necessary it is on the AJ6/16 engines. Their production tolerances were rather better than the XK, and leaks less likely with less use of dissimilar metals.
Al McL
jagcat12
Barrs leaks
Postby jagcat12 » Mon Jun 01, 2009 6:05 pm
Hi I think I have answered my own question when after two years of not using barrs leaks I noticed that the rubber seals on the water rail above the exhaust heat sheilds had started to weep and on adding barrs the leaks stopped.
MikeB
Barrs leaks
Postby MikeB » Fri Jun 05, 2009 8:45 pm
I added one bottle when I changed the coolant last month.
It cured a small weap from the hose to the gearbox (common issue).
Since then the temperature guage has been much more consistent, hovering around half way even with the air con engaged.
Mike.
almcl
Barrs leaks
Postby almcl » Sat Jun 06, 2009 7:56 am
Took my 4.0 to Dave Marks a week back. Normally I do most of the work myself but I wanted to change gearbox fluid, rear axle oil, brake fluid and have someone other than me look at it before the Entente Cordiale.
All was going well until Richard noticed that the radiator was crumbling. A recored one was procured there and then and when Rob Middleton came to fill up after fitting it, he insisted on adding a sachet of Bars.
Interesting that a Jaguar trained specialist has no hesitation in using it.
Al McL
poprivet
Re: Barrs leaks
Postby poprivet » Sat Jun 06, 2009 9:26 am
Your gearbox has a water connection? Tell us more.
