I still haven't got it yet, having the aircon re-gassed next week and then it'll be ready. Hopefully not long to wait now!
A soon to be XJS owner!
Hi Scott,
1995 4.0 Celebration Coupe in Sapphire
Re: A soon to be XJS owner!
Well, the aircon re-gas snowballed into an aircon overhaul! New condenser & receiver/drier fitted and the pipe from the receiver/drier to the evaporator replaced.
Now scheduled for collection next week, will post some more photos then!
Great cars but they need a lot of maintenance to keep in top condition - my sills need constant fettling otherwise the tin worm will ravage them, even on the late models.
BTW - Mine just failed its MOT on a single rubber on front lower suspension arm which required me to make a tool to remove the spring, then I needed to remove the whole hub (you cannot get to the lower ball joint bolt until you release the top joint which requires removing brake calliper etc.!), then you have to remove the arm, press in the new bushes and put back together again! I am taking this as an opportunity to repaint the dust shields and other parts including spring and pan which have some rust on them. All for a simple bush which costs a couple of £s! Still,I love working on the car and a huge pleasure when is back on the road and I can enjoy the ride again.
Just for the record, the correct tool for compressing the front springs can be hired from the Club's tool hire scheme which is operated for us by Ken Jenkins (usually has an advert on the inside the back page).
The front springs have a lot of stored energy which has to be released in a controlled manner to prevent injury so I would only use the proper tool.
