N/S Mirror
petergl1800
N/S Mirror
Postby petergl1800 » Wed Apr 04, 2018 4:25 pm
My off side mirror has decided to stop tilting down when I put the car into reverse, and ideas? :?:
Astromorg
Re: N/S Mirror
Postby Astromorg » Wed Apr 04, 2018 5:42 pm
How are the other functions on the mirror? Can you still adjust it in all directions? Similarly how does the off side mirror behave? My reasoning is that the joystick control switch is known to suffer from internal corrosion. If the switch is taken apart it can be cleaned up, but be warned, it is one of those things that can fly apart if great care is not taken so go slowly!!
This link should help. https://www.jaguarforums.com/forum/xk8- ... ror+switch
Some useful stuff in Post 8 of that thread.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
Re: N/S Mirror
Postby mike020150 » Thu Apr 05, 2018 11:39 am
I have known the mirror lose its reverse position memory for no apparent reason (possibly due to high voltage spikes during winter cold starts) so, if you haven't already done so, simply try resetting its position whilst the car has reverse gear engaged. Mike.
