Hi everyone,
Noticed a coolant leak on the car earlier today so took it to the local garage.
The leak seems to be coming from under the V6 engine and is very difficult to pinpoint without removing parts of the engine.
Been recommended to give K Seal a try to see if that can stop the leak and if not looking at a rather expensive job.
Has anyone encountered anything similar or any suggestions?
Thanks a lot,
Clark
Jaguar XF 2.7D Premium 2009
Coolant leak
Moderator:cawthrm
Re: Coolant leak
Difficult to advise a fix from a distance but can tell you that the RAC use K-seal as indeed have I. I had a small but persistent leak on my V8 S-type a few years ago. Tipped the K-seal in the header tank and the leak was never a problem again.
Hope that helps.
Hope that helps.
