Rear Caliper Rubber seals
Ladams
Postby Ladams » Thu Oct 19, 2017 2:20 pm
Can somebody tell me if the rubber seals on the rear brake calipers on my S-Type 2.5v6 can be replaced?
My local garage is telling me one is split, but says it cannot be replaced and I have to have a new complete caliper.
Is the garage correct or a) is changing the seal too time consuming so not worth it or b) Is it best to change the caliper anyway?
Any advice here please?
Re: Rear Caliper Rubber seals
Postby J44EAG » Thu Oct 19, 2017 5:37 pm
Seals can be replaced, Les. Kits are available.
I believe Oldtimer has done this job and will probably be along here shortly.
Two huskies were talking one day. One said to the other, "You look as if you have blown a seal". "Oh no I haven`t" replied the other huskie. "I`ve just had an ice cream"!
oldtimer
Postby oldtimer » Thu Oct 19, 2017 9:10 pm
Hi Les,
We last spoke at the Jaguar day in the new forest at Beauliegh while you were parked next to Mike K.
I'm sorry to hear about your rear brake problem.
I wrote an article on this subject for the magazine which was published in the Dec 2013 issue Vol29 No12. I'm sure one of our learned members will tell us how to resurrect it. I have my copy on my knee. For somebody about to embark on this task for the first time it is well worth the read, even if I say it myself. Like all these jobs it's down to time and cost.
You did not explain the problem you have with the caliper, is it just a split dust cover.
At the time I made enquiries at the local Jaguar Dealer about a seal kit and was told that there was no Part No listed. Would you believe I have a brand new seal kit in front of me and the purchase invoice. The Supplying company is called Brakes International Ltd Moore st Rochdale Tel 01706 666999. Don't ask me wear I dredged that name from I don't have a clue.
The total invoice for two caliper service kits was £21..88. I f you choose to go that route it is important you have your vehicle details at hand .
This task should be within the capabilities of any mechanic worth his salt
Have you any idea of the cost o a service exchange caliper yet?
I have to tell you LES I would be doing the reseal myself and probably new discs and pads as well.
That's all for tonight but please come back if you think I can be of more help
Montana5
Postby Montana5 » Fri Oct 20, 2017 9:55 am
S Type Forum Moderator
oldtimer
Postby oldtimer » Fri Oct 20, 2017 4:36 pm
Hi,Doug,
That was clever of you to put that link in. Thanks very much, I don't know how to do that. Any how earlier today I sat and read the article again myself. I have to say it was jolly hard going.
Les, I cannot recall if your vehicle has the electric park brake or a good old fashion lever. I would put money on both types of caliper being the same. The only difference being that the cables are pulled manually to apply the manual park brake ,whereas a winch driven by an electric motor pulls the cables to apply the park brake on the electric park brake.
So thinking out loud I reckon it is a strip out job thoroughly clean re-seal and reassemble as per the article. Do not attempt to open up the cassette with the big spring inside you will never get it together again.
IT would be worth examining the two rear brake hoses.
Les do come back if you need more
Les let us know your progress.
jeff1954
Postby jeff1954 » Sun Oct 29, 2017 5:25 pm
That magazine link was awesome. This post is probably to late now but anyone doing this kind of job would be well advised to do one side at a time so that you have always got a reference point if anything goes wrong.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
oldtimer
Postby oldtimer » Sun Oct 29, 2017 6:22 pm
Jeff,
Have you resolved your split caliper dust seal problem. If so please tell us how you did it. This is the second occasion recently that this topic has a arisen.
Postby J44EAG » Sun Oct 29, 2017 7:30 pm
I`ve two X350R brake articles that will be published shortly. One was supposed to appear in the last mag but Nigel ran out of copy space. Part one, front, hopefully in the next mag with Part two, rear, in the mag after that. Part two includes EPB proceedure for reline, switch off and calibrate before recommissioning. It is relivant to any S-type, X350 or XF. If anyone needs this info before we get the articles to press, please call or email me. Details on the header of the X350 Forum magazine header.
jeff1954
Postby jeff1954 » Sat Nov 04, 2017 6:25 pm
Hi Oldtimer I haven't had the problem fortunately with my car but I have done a lot of work on all sorts of cars as I am a time served mechanic.
I have found that it is always best to do one side at a time, more so with drum brakes because of the springs and clips ect, if one goes ping across the garage and you you didn't see where it was attached to you've got the other side as a reference. :D
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
