Oil change on gearbox
Moderators:robv12, DavidEm
VikingJag
Postby VikingJag » Sun Sep 24, 2017 2:42 am
Hello,
I am new to the forum and to the UK. As a foreign post-grad student I figured something quintessential British was needed in form of transport. So I bought an '02 XJ8 SE with 91' miles on the clock with full service history and seems very well taken care of. Having driven the car for a few days now I discovered today the occasional tiny delay in engaging reverse. The car shifts smoothly and no noises from the transmission.
My question is if this merits a transmission oil change or more? And if so if anyone knows a good specialist near Edinburgh that could do the job?
Thanks in advance
- Mathias
RichardSEL
Re: Oil change on gearbox
Postby RichardSEL » Sun Sep 24, 2017 8:43 am
80k is the recommended mileage for Automatic Transmission Fluid and Filter change.
Previously there was no mileage published -- in common with other motor manufacturers Jaguar were saying "It's filled for life, sir!" :?
Don't know any independent Jaguar specialists in Edinburgh, sorry
VikingJag
Postby VikingJag » Sun Sep 24, 2017 1:55 pm
I read that, very strange. Thank you for the respons, will try to find a garage that can do it :)
Postby ptjs1 » Sun Sep 24, 2017 9:04 pm
If the gearbox has never been done before, then it definitely needs doing. 80k may have been appropriate when the car was new, but even then I would suggest that 60k was the right figure. Even ZF who made the gearboxes said that 70k was the limit. I would recommend that the boxes in an x308 need doing every 40k max nowadays.
I'm sure Rob Jenner will be along soon to give you the name of a good independent garage near Edinburgh!
VikingJag
Postby VikingJag » Sun Sep 24, 2017 11:55 pm
As far as I know it has not been done. Fantastic, want to have it done by someone with experience.
Thank you Paul
- Mathias
