Advice needed
shirleysaj792
Advice needed
Postby shirleysaj792 » Mon May 01, 2017 9:29 pm
Hi, I have just bought my first XK8 after loving them and wanting one for many years. I have a couple of things I could do with some advice on -
I obviously want to make sure the car is looked after well and wondered if anyone can recommend a reliable garage in the South Buckinghamshire area. I can obviously seek one out but recommendations are always valuable.
I also need to get a wind deflector fitted - any advice as to which are best or best avoided and again any advice on the best place to get these fitted...
And finally..the batteries in the key have almost ran out, I've read a lot online that changing the batteries means reprogramming the key - is this correct?
Sorry so many questions, just want to get it right :)
Many thanks
mikeanson
Re: Advice needed
Postby mikeanson » Mon May 01, 2017 11:45 pm
Congrats on your most excellent choice of motor vehicle!! I can only help with one question: The battery can be changed in the fob without needing to reprogram. Battery is a 3V Lithium cell CR2032.
shirleysaj792
Re: Advice needed
Postby shirleysaj792 » Tue May 02, 2017 10:49 am
Thank you so much, that's really helpful and much appreciated!
Re: Advice needed
Postby mike020150 » Tue May 02, 2017 4:23 pm
Garage recommendations are best sought at a regional meeting. Members will often be more willing to talk openly face to face than by putting fingers to the keyboard. Alternatively, try a call to your nearest regional organiser whose details will be listed in the magazine. Mike.
Re: Advice needed
Postby mike020150 » Tue May 02, 2017 4:28 pm
Most of the wind deflectors available seem to work well, although some are more aesthetically pleasing than others. If you buy second hand, ensure you get all the brackets etc. Mike.
shirleysaj792
Re: Advice needed
Postby shirleysaj792 » Sat May 06, 2017 7:53 pm
Great thanks Mike, that all makes sense :)
FrankC
Re: Advice needed
Postby FrankC » Wed Jun 21, 2017 11:26 pm
Be aware there are two wind deflector options. If you do not have the pre drilled holes behind each front seats you will have a choice of two types.
First type you have to drill holes in the side leather behind the front seats, around the speaker. Remove the rear seats and drill more holes. I will not explain exactly but it is quite involved.
The second type you have to remove two covers on the 'b' pillar. One side is pre-drilled for a bracket the other side you have to drill a couple of holes. Ok I know that probably does not help much but thought you should be aware of the options.
By coincidence I have ordered the second type and it should be with me with the next couple of days. If you wish me to do a 'how to' all you need do is ask.
:D Hope this helps. FrankC
FrankC
Re: Advice needed
Postby FrankC » Wed Jun 21, 2017 11:27 pm
FrankC
Re: Advice needed
Postby FrankC » Wed Jun 21, 2017 11:28 pm
