central processor fault, car not starting
Postby Brakebuster » Sat Sep 10, 2016 8:06 pm
after going out to the car yesterday evening, the central locking wouldn't work, and the alarm was throwing 50 fits
after calming the alarm down ( pulled the backup battery ) and getting into the car it wont start
symptoms ,
no remote control
no central locking,
no puddle lamps
no interior lamps
no gear release solenoid
no dash panic locking button
NO START
after much investigation and head scratching, i managed to start the car by physically making the starter contact in one of the modules under the passenger dash , yes, i had to take it to bits to do this !! but the car starts every time but still none of the above functions
and pressing the brake pedal will not release the gear selector,
i have discovered that the central microprocessor control unit handles all of these systems , and from the schematics it seems that it has a direct feed from the ignition switch , this could be a supply or ground to the module, or the module is fubar in some way , or could be ( if I'm really lucky ) a connector that isn't quite seated, but the sunlight faded before i could establish this
wish me luck
naki
Re: central processor fault, car not starting
Postby naki » Sat Sep 10, 2016 10:20 pm
Does sound like its died a death.
It's located under the passenger knee bolster panel.
Check for any evidence of damp/ water in the Footwells too.
Especially around the fuseboxes.
I have a spare microprocessor if needed.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
Postby Brakebuster » Sat Sep 10, 2016 10:33 pm
Thanks Naki
dry as a bone in there, ( fortunately/luckily ) ,
i started in the wrong place checking all the microswitches around the brake pedal and by the gear selector, even suspected the linear switch located next to the gear selector, but as the other systems have been effected i ended up thinking the central module was at fault, i will check the feed on "25" from the ignition
i really am hoping that its a loose connection from one of the plugs, but as we all know,......its a Jag , lol
thanks for the offer on the module, its a mid '94 car , with security system ,
what sort of money , as i have put a bid on one on ebay already , lol
cheerz
Postby Brakebuster » Fri Sep 16, 2016 7:35 pm
good news
after obtaining a matching used central processor unit, and ensuring the battery was disconnected, i was grounded, the processor was grounded and had my lucky pants on :oops: i plugged in the replacement unit, ensured everything was seated correctly and reconnected the battery
instantly i saw the interior lights and puddle lights were working , and turned the car over on the ignition, she started without hesitation
so a right result
Thanks to Naki for offering up a replacement part, but i had already bid on one on ebay , which went very cheaply and the seller posted it out asap for me
but i think i may get a spare as well , lol
davidr
Postby davidr » Fri Sep 16, 2016 9:14 pm
Result!!
Well done.
:D :D :D
Postby J44EAG » Fri Sep 16, 2016 9:22 pm
Rare to get a quick fix but as so many services went fubar, it would indeed suggest module failure. The problem with diagnostics is as always finding out which services link to a particular module. That in itself can be a considerable time eater. Once the fault is itemized to a component, one always wonders how patently obvious the issue was and why you didn`t think of the reason immediately. I had that with my nineteen day glitch!
Well done, Mate.
Mike .
db40
Postby db40 » Fri Sep 16, 2016 9:25 pm
A 'well done' from me too. Central processor faults are rare on the XJ40, so far as I know.
(XJ40) 1992 Jaguar Sovereign 3.2 (93MY)
Postby Brakebuster » Fri Sep 16, 2016 9:42 pm
the large hanging down central processor unit with its three plugs, its mounted on a spring clip behind the rail of three smaller relay modules that you have to remove to get proper access
IMG_1936 by MyPix on Talk Photography
one job at a time , lol
Postby Brakebuster » Fri Sep 16, 2016 9:51 pm
and the 20p coin is for turning the plastic stud fasteners, as screwdrivers are to ' sharp ' and chew up the plastic, a coin is just right and i always have one in any car for such fixings, lol
Postby Brakebuster » Fri Sep 16, 2016 10:41 pm
this is the central processor unit with no clothes on........i had to see if a component or track had failed, but nothing obvious, so i must conclude it was an actual chip that has failed ,
IMG_1941 by MyPix on Talk Photography
poprivet
Postby poprivet » Sat Sep 17, 2016 7:16 am
I instantly saw the fault with that circuit board.
It says made in UK :roll:
Postby Brakebuster » Sat Sep 17, 2016 10:15 am
show mw a desktop PC made in 1993 that is still going ? lol
