X350 handling
SCUTHY2002
Love my X350 XJR to bits but the handling compared to my well sorted STR seems skittish on anything other than smooth tarmac when it is fine. Every bush and joint has been checked and replaced with new and both front air suspension units have been replaced. I know I am not comparing like for like due to the air system and the much lighter body weight but I cannot help but feel a little disappointed. Anyone else got experience of S Type against X350??
Re: X350 handling
In my experience, short as it is, I HAD to referb the front end of my 350R at 77k miles. Replaced all front bushes and drifting and hopping cured....However set up is crucial.
Having previously set up an early S-type after a full competition Powerflex rebuild, what I noted on both S-type and X350 was that wheel base length ie rear of rear wheel rim length to rear of front wheel had to be spot on as regards camber set at the rear front drop arm, initial toe and then the wheel base dimension which is 119.4" (3.032mm).
Inflate tyres to the same pressures all around. Initially the rear sub-frame if dropped to replace rear ARB bushes, needs to be set dead right again after being disturbed. ie the rear wheels MUST be millimeter accurate set to the rear wheel arches as a datum. Best if you have Main Dealer geometric gear but more difficult at DIY level. Difficult but not impossible. A tape measure and careful thinking can get that sub-frame in dead square. That is where you start from to achieve correct "total thrust" ie everything going straight and parallel with no side thrust element being present....ie a poorly located rear sub-frame.
Then set the rear wheels parallel preferably at a specialist possessing a four wheel tracking tool..
Then check ride height is at manufacturers default settings with engine running and suspension inflated. Ride height at each wheel MUST be correct. If the car has been electronically lowered, then again levels all around the car must correspond. Height irregularities should be corrected at a Jaguar specialist before going further. Correct with IDS or SDD specialist electronic equipment before proceeding further..
Now set the front positive camber angle at the front rear drop arm using the bolt and cam washer facility to manufacturers camber settings. Then check and adjust front wheel toe which has just a smidge of toe in. Refer to guide line dimensions. Then set the 119.4" wheel base length via the bolts and cam washers on the front banana arm to front of front of sub-frame to get that critical 119.4" wheel base length. Check and adjust camber again and toe and caster at least three times. Each time you move one of the six dimensions ie three adjustment points each side at the front, other dimensions will change. This takes great patience, a knowledgeable four wheel tracker operator and an assistant. Plenty of coffee, patience,a logical thought process are pre-requisites. The tape measure is a "must have" without which decent set up is pure guess work. I`ve been hands on on setting up my 350 and this method works a treat. It is very similar to that used on my old S-type with small detail changes.
Once all is correct, the car should drive straight and not squeal tyres or hop, skip or jump down the road. I know this occurs as I`ve experienced this myself only two months ago. Properly set, the car is a joy. Fractionally out and the car can do as you have described and be most disconcerting to drive..
SCUTHY2002
Re: X350 handling
Hi Mike. Thanks for the info. AWJ in Stoke went through the whole car for me when I bought it and found 7 bushes with some wear so I had them all replaced. They also did the alignment. Also had a new set of tyres but it can still be scary cornering on an uneven surface. It is really spoiling the whole XJ experience. My STR is far more planted. Might have to entrust to another specialist for a second opinion because this cannot be right! XJK is only a few miles from me.
Re: X350 handling
As i said in my previous post, set up is really critical with tracking toe, camber and caster together with rear toe set as the starting point for all that comes after.
Another important aspect is uniform ride height which must be set to manufacturers default height before attempting any set up. The car needs to be electronically leveled before beginning any adjustments and I found that best achieved with the engine running during the leveling procedure AND when setting up toe, camber and caster angles. Tyre pressures must also be checked before any adjustments are made.
Correct air suspension unit operation needs to checked also. It is very different to normal damper and coil over systems.
I would take the car to a specialist tracker operator before going further. The wheel base length at 3.032m MUST be the same either side. The man doing the job does need to be an expert. My best results were obtained by rigidly adhering to the aforesaid dimension at the expense of ignoring what the electronic machinery showed on the screen.
My car was a very bad to drive when I first squired it. As I replaced a matched pair of bushes across the car, it would throw geometry out and throw up other wear points. One thing would lead to another until I replaced every single bush on the car. Having now run S-type and X350 for many years and learned their suspensions, I`ve found that replacing just a few bushes here and there to be unsatisfactory. I can only say that once you change a few bushes in isolation, it is difficult to get a good driving car until the whole lot has been changed. From around 80k miles, standard OE bushes can and do degrade significantly. Even just minor degradation has a significant effect. I`d also add that I no longer fit OE bushes to these cars and favor the polyurethane Powerflex Purple and also Black Series which are rather more resilient and are warranted for life against later failure.
Worn ARB bushes also affect geometry particularly at the front end of the car. geometry changes markedly with the ARB disconnected or with the vertical links not fully tightened.
Jaguar suspensions will have an average mechanic running for the tea room in panic. Precise knowledge is essential to anyone attempting to keep these suspensions in good order. I`d suggest the car be taken to a Jaguar independent operator rather to a general repair garage unless they have specific Jaguar knowledge.
Let us know if you need further assistance.
SCUTHY2002
Re: X350 handling
Thanks Mike, fountain of knowledge as usual! I know Rob is a big fan of XJK so I might give them a try after Paramount have done their magic! Steve.
Re: X350 handling
This is an interesting thread I had a 3.0 s type till 2008 but have owned a 2.7 X358 since then,
I have always felt that the XJ holds the road better than the S type did even when i did need some bushes changing at the back.
I guess that engine type must make a big difference in the same model car.
I Noticed the difference most when driving abroad at higher speeds than the UK. My S type always felt skittish at higher speeds whilst the XJ seemed to just get better.
Re: X350 handling
A standard, especially the early model S-type with the so called "comfort" suspension ie very springy springs and rather soft dampers could be very lively indeed. Cars fitted with the slightly stiffer "sports" suspensions were better. CATS equipped models being better still.
The X350 suspension being CATS controlled, air bag type is a rather more sophisticated set up. My R has the "red spot" sports dampers with 20" wheels and it isn`t bad at all. Perhaps just a little float from the front end when the suspension reaches the top of its travel when being driven quickly. The experience improves further when Powerflex type lower front bushes are fitted. Altogether a more accurate steering feel results. Changing top bushes also for polyurethane Powerflex gives a much quieter, less crashy feel once done.
Engine weights will not make that much difference to the ride. You would be hard pressed to notice much difference across the range. However accurate camber, toe and caster angle set up makes all the difference in the World. Set spot on, the whole car improves dramatically. Wear in any part of the suspension has a marked knock on effect.
Mike.
Mike.
Re: X350 handling
gotta chuck in my thoughts here, wheels and tyres!!! X350 rides best in 18 inch imo, however and XJR looks far better on 19 or 20's that I do agree with
I had a 4.2 V8 on 18's drove like a dream, it REALLY did, I have an XJR on 19's and its fine if the tyres are all good and matched and at the correct pressures, however, I have had two XJR's on 20's one a 2006 in Sepangs, and a 2008 358 on Callistos, both look stunning on these wheels, but both are lively to say the least, they tramline and can seem skittish in the wet or uneven surfaces, un-nerving at times
The 2006 car, now sold, had a thorough and I do mean thorough make over by XJK to the tune of over £5K, that included all new bushes, front a rear, arms, and shocker bushes, yes it drove fine afterwards, but that was it "fine" not brilliant , 19 inch on an R or any 350 would be my compromise for looks, comfort and handling
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
Re: X350 handling
I agree with Rob that on 20" in the wet, handling can be skittish! My solution is to run tyres at 36psi and that does indeed improve traction. Yes, the ride did become firmer but I don`t mind that. The DSC will often intervene or interfere....depends how you see it. I`ll often switch it off and rely on my own inputs for any correction needed. Thats contrary to what you might imagine as a good idea and seems to give a more predictable and rewarding drive. No doubt an LSD would tame the car further.
I`ve spent the last couple of years changing bushes on the S-type and this 350R. Firmer polyurethane bushes on the lower arms give a well planted feel. A hard Pwerflex Black Series fitted to the front rear drop arm stops apparent scuttle shake with a softer Purple Series on the front banana arms gives a lovely feel.
As regards the rear lower wishbones, I confidently expect to stop a bit of skwinney from the back end when I get around to fitting two reconditioned lower wishbones to the car when weather is nicer. I expect to find a fair amount of wear in the upper rear wishbone bushes.The recon lowers again have Powerflex Black fitted to the front inner registers as per my experience with the S-type and will help towards a more straight line experience at the slight expense of ride comfort. You feel the tightness and know the car is a bit harder nosed.
20" rims and 35% tyres are really best for the push on enthusiast. 19" will most certainly be a better option for a driver seeking a more compliant ride.
Changing bush grade can allow a considerable change to a vehicles driving dynamics. i`m not certain people really realise what can be achieved. You can go hard or soft. The choice is up to an owner. The subject doesn`t need to be a black art. A call to Powerflex R&D engineer, Paul, can help you decide what you want to achieve. I`ve found the fellow very helpful.
I`m probably the total minority within the JEC when it comes to experimentation with these vehicles. I don`t know anyone else bush bashing to the extent I`ve done. Believe me when I say the results achieved exceed my expectations. All I can say is try a set of Purple Powerflex when you next have the need to change bushes. You will not be disappointed.
Re: X350 handling
Mike,
This is a fascinating account of how to set up the suspension properly, but two questions:
What is the appropriate wheel base dimension for LWB cars?
Where do I find the correct spec for camber, toe, caster etc.? You make mention of these without specifying them. Is there another thread on here that I've not found yet?
My car was driving OK when I got it, but I was advised to swap the steering rack and replace the banana arm bushes. This done, I took it to my local garage for alignment and they managed to screw it up completely, including setting a massive toe out. They are Scoobydo specialists, so can't blame them too much. I now have the tow in set correctly (by local tyre place with Hunter kit), but the car is not driving quite as well as it should. The local tyre place, though having top gear will only set the toe. I'm near Aberdeen so way away from decent specialists.
Roger
Roger
Roger S
Aberdeenshire
Early E
X350 - 2005 Super V8
1962 MGB
Aberdeenshire
Early E
1962 MGB
Re: X350 handling
Right, this is how I set an X350 up. This method also holds good for the S-type or the XF. However with those two models, the wheel base length is different to that on a 350. The X350 is a longer car, hence dimension differences. To set these models up accurately, requires the help of a good alignment garage with four wheel equipment. Even then, some garages that state they can align with their four wheel gear, often fall flat on their faces when it comes to obtaining caster angles on these cars. However, this can be worked around as follows.
Specs for alignment can be found on the internet but a specialist should have a data base on his equipment. I recall that the info may also figure in the Drivers Handbook. Note, many garage people cannot tell the difference between the seven XJ models made over the years so it is important to make sure they understand which model and year of car that you have presented them with. I had one guy who was near tears setting my car up until I intervened and defined which model and year of car was in front of him! If it can happen, then it will.
Firstly, the suspension height needs to be uniform as described in the Jaguar IDS or SDD diagnostic equipment data base. My own car sat unevenly when I first bought it. I took the car to Tom Lenthall near Reading to have a number of jobs done which I could not or decided not to do myself. SDD allowed Tom to electronically add or subtract height levels on each damper until the standard ex-factory ride height was achieved. Tyre pressures were set to 34psi on my 20" rim equipped car. Manual measurements were taken with a tape measure from the wheel arch to the centre of each hub which were noted down on paper with discrepancies to ex-factory measurements then being easy to calculate. My car showed discrepancies of up to 26mm. Someone previously had been messing about! The parameters where adjusted electronically to level the car. That done, I had the car lowered 25mm all round to help reduce body roll on cornering. In my opinion that also helps the appearance of the car which I feel looks awkward at standard height. Doing the above is the first stage of setting the car up before a geometric check and adjust session.
That done, the car should be driven onto the garage alignment bench and tracking equipment fixed to all four wheel rims. I insist that the car engine is left running so that the suspension is kept pumped up to the leveled height throughout the session.
Firstly, rear toe (tracking to parallel) is checked and if required, adjusted. With luck the rear sub-frame will not ever have been removed and it will be sitting squarely exactly as it left the factory. It is from the back wheel alignment that all other calculations are then derived. Any deviation from total accuracy at this point will completely ruin any attempt to correct the front end of the car. Only rear end toe angle adjustment is possible on S-type, X350 and XF models.
Moving to the front end of the car, begin by having the front toe angles set to parallel. The camber angles should then be adjusted to one degree positive inclination. ie the tyre at the top points outwards towards the wheel arch with the bottom of the tyre inclined inwards to the centre line of the car. Adjustments are made via the location cam action bolts on the lower drop arm. Slacken one nut at a time and turn the cam action bolt to move the drop arm in or outwards in a slot in the front sub-frame. To obtain the one degree positive camber angle, it is likely that the bolt will finish up turned so that it touches or nearly touches the inboard end of the slot in the sub-frame. That is how it is on my X350R. The equipment attached to the wheel rims transmits to the control screen to the alignment gear and an accurate positive or maybe negative angle may be seen. Adjustments should be continued until that camber angle has been achieved. Nuts on the camber bolts should then be fully tightened. Tighten the nut ONLY and hold the bolt from turning. If the bolt turns, then correction will have to be carried out again. Once the correct camber angle has been achieved, re-check and adjust tracking toe to just a tad negative (rims set to just inward at the front edges from parallel.)
At this point, caster angle should be set. This is the inclination of what used to be called "king pin angle". If correct, as a general rule, the front wheels should be central to the wheel arch profile. "Set forward" is where the wheel, un-centralised, sits towards the front of the car. "Set back" is where the wheel sits again un-central to the wheel arch but this time the bias is to the rear of the car.
Caster setting is what can have the mechanics running off to the crew room never to be seen again. It is not unusual to find seemingly well equipped four wheel alignment garages with equipment that cannot cater for caster angle alignment. Hence the ensuing localised panic evident at that point. However, there is a "work around" solution which is simple and effective and which is the method my local alignment guy and I use to set caster angles to perfection.
The wheel base length on a standard short wheel base car is 119.4" and nothing else! The wheelbase dimension for an LWB car is 124.4". Take a long steel reel type tape measure and a piece of bright insulation tape. Place one edge of the insulation tape on the tape measure at 119.4" and stick it firmly onto the tape measure. This is a vital measurement. Two people are then needed. Take the tape measure and have one person take it to the rear wheel and place the zero end of the tape on the rear of the rear wheel rim. The other person extends to tape measure until the bright insulation tape mark at 119.4" hopefully touches the rear edge of the front wheel rim. Take care to ensure each person holds their end of the tape measure across the centre line of each wheel rim. The 119.4" mark on the tape will exactly align on the front rear edge of the rim if caster angle is correct. 119.3" would indicate "set back" is present and adjustment is needed. Similarly 119.5" would indicate "set forward". Adjust would again be needed.
Caster adjustment is carried out by slackening the nuts on the bolts which pass through the large front banana arm bushes which locate in the front mounts of the front sub-frame. Again the bolts are the cam action type as described above. The bolts again locate in slots in the front sub-frame and carefully turning the bolts one way or the other will allow the correct caster angle to be achieved with the required 119.4" wheel base length being set. Once achieve, fully tighten all nuts ensuring the bolts do NOT turn in the process. That`s caster angle correctly set.
Once again check and adjust toe angles and lock off the nuts on the steering rack drop arms. That done, re-measure wheel base length and ensure it is still 119.4". Adjust again as required and the adjust toe angles again if required. Go around and around until you get all required dimensions. Then the job is done.
After a full re-bushing session and then an alignment session doing the above actions took the alignment guy and I just ten minutes to achieve on my car this year. A few days later, PTJS 1 bought his car down to me having fitted reconditioned rear lower wishbones. His car took just five minutes to set up. Sometime later, I took a so called repaired five litre XFR to the garage for alignment after the owner re-bushed the entire suspension. After an hour and a half session on the alignment bench, we failed to achieve correct caster angles on the NSF suspension. Subsequent further investigation revealed a bent and cracked sub-frame which stopped us achieving correct caster angle alignment. The car had an astonishing incorrect 5/8" set back on the nearside wheel which if you look carefully can clearly be visually seen in this image. A new sub-frame is needed to correct heavy frontal impact damage. This shot shows the OS of the car and the front wheel centralised in the wheel arch and with the correct caster angle having been easily achieved. Correctly set up, these cars will handle like a dream. Worn suspension components, incorrect alignment, accident damage or nasty tires can cause them to drive very badly and can cause a few handling scares. Get them right and you will love them to bits.
Hope that helps.
Hope that helps.
Re: X350 handling
Mike - great instructions - thanks. I'll report back once I investigate further.
A couple of thoughts: would this post be better in a different section? Would this form a good magazine article or has it been covered already?
Roger S
Aberdeenshire
Early E
1962 MGB
Aberdeenshire
Early E
1962 MGB
Re: X350 handling
Good point, Roger. Really this thread should moved to be in the suspension section. Paul, is better at this sort of thing so no doubt he would be able to shift it shortly.
The X350 pages in last months magazine effectively cover what is being discussed here. See the July 2016 magazine edition where I describe knocking down and rebuilding a banana arm front suspension. In addition suspension reworks have also been covered in earlier X350 and S-type Forum pages.
Re: X350 handling
Sorted!
