Window Trim refurbishment.
clivesaunders
Postby clivesaunders » Mon May 16, 2016 2:47 pm
Convertible XKR 2002 I wish to repaint the Qtr light & possibly the door trims.
I noted article by Ron Tennant Jan 2016 who used Humbrol matt black. Am I correct to assume the black / graphite colour is the 'same' for all cars whatever the body colour ..?
Is there a Jag colour specification for these trim as I would like to try and match the original paint Spec.?
Thanks for assistances
Clive @ Peasemore
GrandTourer
Re: Window Trim refurbishment.
Postby GrandTourer » Mon May 16, 2016 8:10 pm
The most common trim colour for the outer trim around all windows, screens is called Jaguar Dorchester Gray. I will try to find the colour code, which I have somewhere, and come back with this info - hopefully.
Karl, XK8 MY2000 Pacific Blue
GrandTourer
Postby GrandTourer » Mon May 16, 2016 8:28 pm
The info I have located is the colour is Dorchester Grey 342 / LDP. It is available from Jaguar Dealers in small touch-up bottles with application brush (about £10 - £12) or you should get it in aerosol cans or premixed in cans.
By the way, the same colour is also used for the two door mirror brackets and other Jaguar models.
Hope this helps.
clivesaunders
Postby clivesaunders » Thu Jun 09, 2016 5:09 pm
Thanks so much for the info...appreciated, have agood summer
Clive Saunders
FrankC
Postby FrankC » Sun Apr 02, 2017 10:14 pm
Just in case anyone else has this problem you may find this useful http://www.jaguarforum.com/showthread.p ... post989398
Its quite a common problem on our cars. Hope this helps someone.
