Heated front screen
Moderators:Popsjag, J44EAG
bozthesax
Heated front screen
Postby bozthesax » Fri Jan 22, 2016 11:47 am
Anyone know where the fuse is located for the front heated screen? Mine isn't working, thought the fuse would be the first thing to check, the handbook says there's 3 fuse boxes! :shock:
Re: Heated front screen
Postby J44EAG » Fri Jan 22, 2016 5:25 pm
Page 6-24 of the owners hand book refers.
The fuse is in the passenger A post side panel just to the right of your right foot.
Fuse F1 controls the front screen and several other functions as well. The had book shows what other circuits also operate via fuse F1
Fuse colour is red and 10amp rated. The fuse type is ATO.
If other circuits which are on that fuse are working, then you may assume that there is some other fault within the controls of the front window heater circuit. The high current is probably controlled by a relay. Sorry, I don`t know which one but perhaps also in that cabin fuse box.
Hope that helps.
bozthesax
Postby bozthesax » Mon Jan 25, 2016 9:20 am
Many thanks - I'll check it out. There doesn't seem to be any other non - working items, so it's either the screen or the relay at fault then I guess.
