I bought the car which is in need of restoration it had stood for over 30 years in a USA garage, the body is sound with minimum work required, the engine was seized.
It has taken time to start working on the car but I have now removed the engine and gearbox, took it out through the bottom, much easier than I thought.
I had soaked all the bores with a Petrol / Oil mix for several months as the engine would not turn over by hand.
I have stripped the engine down and found as I thought all the pistons are seized, very little rust was found on the visible bores which I have removed. No-6 cylinder had a very tight con rod and looks to have been starved of oil with discoloration on the piston and con rod.
I have in my workshop a 10 ton hydraulic press to assist if required.
Hope someone can come up with some good news, at the moment I think it is all bad.
Regards Frank.
MK2 3.8 Seized piston removal
Re: MK2 3.8 Seized piston removal
Hi Frank,
Unfortunately I have also been there, Our car was a wreck and had stood for 30 years, I tried diesel, release oil even coca cola, all to no effect, so I took out the crankshaft and with a specially made drift I knocked each piston down the bore until loose and the back out the top (rings corroded to the steel liners).
The drift was a sleeve just smaller that the bore, a flat plate on top and a thick steel tube ontop and battered with a large hammer, working on shock loading to free the pistons. They came away surprisingly easily.
The whole engine was rebored and crank reground, easy then (15 years ago) as there were plenty of small machining businesses about.
Obviously you have the head off so can I suggest you go the whole hog and knock out all the core plugs and clean out the spaces, depending how it has been stored and how long you may well have a crust of very hard material (rust) about an inch above the bottom of the water space, this needs to be removed and all this space cleaned as best you can.
Like you I prefer to unbolt the front subframe and wheel it away then lower the engine onto a very low trolley and pull engine and box out in one unit.
Best of luck
Best of luck
moraledagd14
Thanks Brian. I have already machined some sleeves to press the pistons out, I had a fare load on them with no movement and was a bit frightened I did major damage to the block.
I will modify one and give it a go.
I have the crank removed as you would expect but being unable to remove the con-rods it is a bit tight to knock the pistons up the bores, I guess another drift will have to be made, the plus side is as a re-bore will be needed I don't need to worry about the pistons but would like to save the con-rods
Regards Frank
Regards Frank
moraledagd14
Brian was right, a good fit drift a solid base and a lump hammer did the job. The pistons moved quite easy, I used the press and a hardwood spacer to push them out of the block.
The bores looked not bad so I honed them, they are now OK but I have 3 thou oversize. Can anyone advise if this will be OK with new pistons and rings (don't want to chance the old pistons) or should I re-bore to +30.
Regards Frank
Regards Frank
As I'm sure your aware the 3.8 engine is effectively a 3.4 overbored and a steel liner pressed in to stiffen the bores. The less this is machined the better, mine required overbore to the next size available (can't remember what), full crank regrind, new pistons, rings, shells and for good measure crank balanced and rods checked. That is going the whole hog, but I know I have a good solid and balanced engine to work with.
If you are going to the cost of new pistons and rings then it seems sensible to have a rebore.
You may also know of the muck traps in the crank (plugs in each crank that NEED to be removed and cleaned out and new one put in).
This is an old fashioned engine and cost cutting will comeback and bite you.
I would say you MAY get away with a 3 thou polish of the bores and a polish of the crank pins, but I would personally ask a professional machine shop to assess it for you and take their advise. Also replace the oil pump as a necessity.
The oil pump feeds the mains and then big ends first, any slack in them means the oil leaks out easily and the rest of the engine is on low oil feed. For me this is not a good idea! Knowing of the low oil pressure these engines can suffer from I fitted a larger pump and lift and supply pipe from an XJ6 (advised and supplied by Ken Jenkins at the time some 16 years ago).
At the time I rebuilt my engine for £2000, the same as a proffesional rebuilder and I knew the quality of the guts of it.
It is your engine so your choice, but professional help and advice will pay for itself.
moraledagd14
Hi Brian
Yes you are right, I had thought that myself, money is not too much of an issue as I want it right. The problem I have is I live in Granada Spain, I am a member of the Granada veteran car club so I will ask the locals if they know of a good shop that can do the work.
I would change the Oil / Water pumps anyway, I am interested in the oil pump upgrade you did can you give me a bit more detail.
Regards Frank
Regards Frank
These are tall engines and oil needs to get to the camshaft bearings as quickly as possible on start up. As I mentioned before wear in the mains and big end bearings will compromise this and oil to anywhere else. A well built engine to original spec will not have a problem.
A talk to an engine builder just over a year ago raised the problem of poorly made standard pumps (the pump landing face was angled and so the pump would have sheared off on start up). I just wanted a bit more oil flow for protection later in its life, plus the fact that I fitted an aftermarket spin on oil filter which apparently can cause a restriction and reduce the oil flow.
Oil pressure readings are to two edged sword, if it is before the filter then its a false reading, after the filter it gives you the oil pressure feeding the bearings and can be a check on bearing wear (assuming it is a proper capilliary gauge).
I fitted an XJ6 pump which is bigger and a higher flow rate that results in higher pressures (irrelavant). The XJ6 suction and delivery pipes are larger bore and need a little modification to fit and seal properly.
The down side to this is the ability of these engines to leak (they are good at it). Early engines like mine had a 4 bolt oil filter mounted to the side of the block and it leaked, a later 5 bolt filter fitted and an extra hole and thread was drilled and taped to secure it (not leaked since). Mine is an early engine so only has the now worn and poor scrowl on the crank to throw oil back into the engine. Due to the number of rear sealing arrangements available now especially if yours is an asbestos rope seal engine I would go down that route (I would have if it had been available 16 years ago).
I was advised at the time to use a thinner more modern oil to get to the camshafts so used 10w40 semi synthetic and have done for 16 years. More recent advise has been to use something like 20w50 so I have 15 litres of Millers semi synthetic ready for the next oil change (should last a year. Incidentally very early on I tested the original and tired electric oil pressure gauge against my capilliary gauge, at no point did they agree, I also check the oil pressures when on the old 20w50 and the new 10w40, no change of pressure. I'm hoping that the leakage will be less with the 20w50, but accept the oil loss as part of the use of old cars.
Best wishes
Best wishes
moraledagd14
Hi Brian
Thanks for the heads up on the spin off filter conversion, at 400 pounds you would think it was better. My filter unit has the five bolts, so good news there.
I have been restoring old motorcycles and cars for over 30 years (first time with a jag) and found that modern gasket materials are not as good as the original and can leak if you use hermertite, I always use Nural 28 as it has a silicone base I have a Panther M100 that does not leak a drop some would say it is a miracle.
When you say the XJ6 pump oil pipes are bigger bore and need a modification do you say that the "O" ring needs to be bigger or a sleeve made for the original pipes? can the XJ6 pipes not be used?
SNG Barrett have an up-rated pump that requires an adapter for the pump drive, have you heard anything about this?
I will look into the oil seal conversion as mine is the rope type.
Can you remember where you bought your pistons and were they AE.
Hope you don't mind me talking to you about this but I would like to get things right first time and anyone with prior knowledge is invaluable to me.
Regards Frank
Regards Frank
Hi Frank,
No problem, I made mistakes along the way (expensive) so try and help others so as not to. I've looked in my photographs (before we had a digital camera) and there are none of the underside of the engine, my writeup of assembly is only a few lines..........'bore +20 thou, crank -10 thou, planned 5 thou (block top and front cover machined down). I remember that the XJ6 pipes obviously fitted the pump, the suction pipe fitted the stone filter in the sump after the hole was 'adjusted'. I can't remember about the discharge pipe to the block, no great problem as I remember.
I remember asking Ken about a 'Mallory' pump which was expensive and he suggested and supplied the XJ6 pump and pipes.
The piston, rings and shells were all original AE and similar makes. Although the pistons were supposed to be a matched set I borrowed Lesleys kitchen scales and weighed them then added nuts and washers to the lighter piston up to the heaviest piston, quite a pile. Balancing is well worth it.
Do you mean someone is asking £400 for a spin on filter conversion?????? I paid £35.
I forgot to add the old tin sump would not fit and had to be panel beaten down a bit, don't know about the later alloy sumps.
moraledagd14
Hi Brian
Did you have to alter the tin sump to accommodate the seal conversion. I have a tin sump.
Yes £400 I thought it was bit over the top, anyway there is nothing wrong with standard filters as long as you change them regularly. My engine came with a mesh filter that looks like it had not been cleaned for ages. Then again it is not the first engine I have had from the USA, the last one had more stripped bolts in one engine that I had seen over 20 years I don't think they are great with the spanners.
Thanks again for your advice
regards Frank
regards Frank
Hi Frank,
I thought I had read it wrong at £400, someone is lifting peoples shirt tails!!!! Mine is just a piece of steel with a thread at each end and as large a bore as possible, this takes a very large canister fitler. The guy who made it sold the idea to one of the big suppliers I think.
When you look at the oil pump in situ, it is tilted over at an angle (the same as the distributor angle) with the result that two of the bolts are close to the sump. The longer XJ6 pump will not allow the sump to sit down, but a little bit of work to dimple the sump to allow for the two bolt heads does the job with ease.
The idea of using a proper lipseal did occur to me and I looked at ways to fit one, but not having access to castings to hold the seal............I gave up and stayed with the old scrowl. I know that Ken was looking into this a year or so ago but everything aftermarket and premade for Jaguars is expensive.
I look at my uprated brakes, power steering mods, alternator conversion, later wiper system and servoed clutch and am shocked at the after market prices asked.
Can I suggest you look at all the old and recent posts on here as there is a lot of very good information available, in particular about lighter operation of clutches.
Best wishes
PS try looking at David Manners website, far more reasonable prices for conversions!!
Best wishes
