Earliest XJ40 V12 ?? Production/launch info
robv12
Re: Earliest XJ40 V12 ?? Production/launch info
Postby robv12 » Tue Mar 31, 2015 5:24 pm
ok here we go, this info is 100% correct, I cannot divulge the source and have only published some of what I have been given
V12 intro at 674582 is WRONG!!
the first V12 XJ40 to production standard was vin 673299, which was despatched 18/01/1993, production started in Oct 1992, the car in question 674413 was despatched on 02/02/93 and is 175 cars after intro at 673229. It is a Jaguar Cars car, but the role is unknown, and is too far down the line to be a pre production car. However there is an outstanding recall on the car which has never been attended too!!, probably too late to worry now
There are also 44 cars BEFORE vin 673299, these will be the pre pro cars
all proto's were built April 1991 to June 1992, most with 5.3 engines
hope this helps
Cheers Rob J
pjb1969
Postby pjb1969 » Tue Mar 31, 2015 6:18 pm
Thanks Rob,
it probably doesnt warrant restoring then, it needs lots of work, if it turned out to have a significant/interesting past it may of justified a restoration. For now i will try and get it running then put it away in the dry and decide its fate at a later date.
Thanks again
pjb1969
Postby pjb1969 » Wed Apr 01, 2015 6:23 pm
I collected the V12 today and its very rotten underneath and around the sunroof, damp inside, due to the amount of work it needs and the fact its not a pre production car as i had hoped, it will be broken for spares, the engine will be kept for a future project.
robv12
Postby robv12 » Wed Apr 01, 2015 6:26 pm
shame, but we cant save them all can we
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
pjb1969
Postby pjb1969 » Wed Apr 01, 2015 8:01 pm
It is a shame but the amount of work needed makes it non viable, if it were a significant car as i had hoped, i would have one day restored it, unfortunately its not so i will save the engine for a future project (possibly 6.0 manual series 1 xj) and break the rest.
Postby ptjs1 » Thu Apr 02, 2015 1:16 pm
pjb1969,
If you're keeping the engine, then keep all of the ancilliaries which are peculiar to the engine. For example the engine ecu is specific to XJ40 6 litre cars, so make sure you keep that!
Good luck with the breaking.
robv12
Postby robv12 » Thu Apr 02, 2015 2:35 pm
in fact bear in mind, LOTS of 6.0 XJ40 stuff is unique, essentially everything forward of the screen is unique, except the shell, wings, bonnet, bumper and lights. Brakes, subframe, oil cooler, air con, the lot, its all bespoke stuff
pjb1969
Postby pjb1969 » Thu Apr 02, 2015 9:00 pm
Thanks for the info Rob
Postby Brakebuster » Thu Apr 02, 2015 9:01 pm
as she stands, how much could she fetch , as its the exact car i would be looking for my next project
BB :shock:
pjb1969
Postby pjb1969 » Thu Apr 02, 2015 11:16 pm
I think its a bit past it as far as being put back on the road, worth more in bits id say, inner, outer sills, edge of floor all rotten due to water ingress while parked up since 2006, if it had been a signifiant car i would of been prepared to restore it.
Postby Brakebuster » Fri Apr 03, 2015 9:07 am
cool
you obviously haven't seen my ' rusty ' posts , lol
cheers
naki
Postby naki » Wed Apr 08, 2015 2:50 am
cool
cheers
or mine!
why is it always rust? :roll:
infact t keep everything if you part it out.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
db40
Postby db40 » Mon Jun 22, 2015 11:10 am
cool
cheers
I'm a bit late here, but I remember your rust and restoration photos of the XJ-S. Nothing is beyond your skills, Brake buster!! :D
(XJ40) 1992 Jaguar Sovereign 3.2 (93MY)
Simont485
Postby Simont485 » Thu Sep 10, 2015 9:30 pm
Thanks for the parts Paul much appreciated!
Just for info really. There are a couple of labels on the underside stating Development Assembly and a date of Dec 1992.
No idea if its any different from a later dash....
Simon
1994 Jaguar XJ12 6.0litre
1996 Jaguar XJS V12 6.0litre
robv12
Postby robv12 » Fri Sep 11, 2015 10:28 am
nope standard dash, and believe it or not all XJ40 dash's have "development assembly" stuck on the back!!
Users browsing this forum: No registered users and 15 guests
