Cruise control
hamracing
Cruise control
Postby hamracing » Sun Jul 12, 2015 12:23 pm
I have a 2001 XKR Today the cruise control stopped working. The light comes on on the switch but will not engage. I then found if I adjusted the speed with the cruise control switches on the steering wheel the cruise control engages and can be adjusted up and down.Any idears what could be the problem. No faults showing.
Re: Cruise control
Postby mike020150 » Wed Jul 15, 2015 9:03 am
The first port of call for erratic cruise engagement is the brake light switch. It is a pain to change because access is awkward but it can be done. Try observing when the cruise control works and doesn't work. If the brake pedal has been touched in between, it may give you a clue whether the switch is faulty. Mike.
Users browsing this forum: No registered users and 26 guests
