Pre face lift clock facial panel removal ?
lilium
Postby lilium » Tue Jun 16, 2015 9:40 am
Could anybody tell me how to remove the wooden panel holding the clock/light switches on a 1990 pre face lift as I need to verneer this again? Many thanks
lilium
Re: Pre face lift clock facial panel removal ?
Postby lilium » Fri Jun 19, 2015 6:13 pm
A big thank you to Andy at Just xjs. I sent him an email and a prompt reply from him.
PaulE
Postby PaulE » Fri Jun 19, 2015 9:48 pm
Are you going to share the answer with us then?
1994 Coupe AJ6 engine
lilium
Postby lilium » Sat Jun 20, 2015 12:50 pm
You can just pull the clock out if somewhat gently. The facia is just pressed in, gently lever it out from its press pins.
Yet to try to do it yet!
lilium
Postby lilium » Tue Jun 23, 2015 11:12 pm
Popped the clock out tonight and gently pull off the panel. You need to take care pulling this off as the metal to this panel is very thin and will bend out of shape with little effort!
