3.4 engine weight
stiky
3.4 engine weight
Postby stiky » Sat Nov 22, 2014 10:37 am
Can anyone tell me the approx/ weight of a 3.4 s type engine i am embarking on my winter project to change the rear oil seal hence engine out and i am not sure what size engine stand to buy would a 450 kg stand do.
cheers jim
piman
Re: 3.4 engine weight
Postby piman » Sat Nov 22, 2014 9:38 pm
Hello Jim,
something in the back of my mind says about 7 to 8 cwt, which is about 400 Kg. However a six cylinder engine at 400 Kg is a greater load on the engine stand than a four cylinder engine at 400 kg because the centre of gravity is further out so the load increases on the stand.
For peace of mind perhaps the next size up is a better choice?
Postby J44EAG » Sun Nov 23, 2014 1:40 am
On the basis of that calculation, this unit might suffice. Good price as well.
http://www.ebay.co.uk/itm/1000lbs-450kg ... 2423&rt=nc
Just ordered one myself. After the fun I`ve just had rebuilding a Perkins 4.108, I`ve had enough of turning engines over on the floor to fit pistons, rods and cranks. At least I will now be able to work in comfort rather than on hands and knees! Advancing age is a terrible thing!!
piman
Postby piman » Sun Nov 23, 2014 11:20 am
Hello Jim,
from Google, an XK 4.2 engine weighs about 275 kilos with flywheel and manifolds. so that stand will be fine.
stiky
Postby stiky » Sun Nov 23, 2014 1:57 pm
Hello Jim,
Hi Alec i take your point about the centre of gravity but at 270kg as you say the 450kg should be ok.
NB
Can the rear seal be changed in situ with the gearbox out of the way ??
many thanks jim
Martec
Postby Martec » Sun Nov 23, 2014 5:09 pm
Its a shame you didn't go to the XK engine seminar at Castle Bromwich yesterday as you would have seen photos of the fitting of a 'White' asbestos rope seal being pressed into the two seal housings, clamped to the block and sized apparently over a few hours with the special tool (crankshaft removed). Comments were made by Bob Bates and David Marks about the disaster of trying to fit the later Black rope, and of Ken Jenkins talking of the replacement kit to fit a split lipseal which I believe is for sale now or soon (I saw this or something similar on Ken's desk a few months ago).
Apparently there is also a kit for the earlier scrowl 'seal' which requires skimimng undersize or the crank to remove the scrowl on the crank.
piman
Postby piman » Mon Nov 24, 2014 9:12 am
Hello Jim,
unless you already have a lip seal conversion then the answer is no, as the crank needs to come out to size the rope seal properly. Ron Beaty's video which I have says you can size the seal using a socket bar extension to smooth it into the groove but I suspect that would be hit and miss if you have not done it that way before a few times?
Brian, I was at that seminar and found it very informative, well worth going to.
