Hi.
My car which is a 65 S type is in the body shop having a bare metal respray. The door hinges
screws are not in the best condition. So I'm trying to find replacement fixing. also I want to replace the strike plate and lock catch screws as well. Does anyone know where I might find
anywhere I can get these.
Regards Ricky
door fixing screw.
stuarthardy
Re: door fixing screw.
Hi Ricky
The following part numbers have been taken from the parts manual for my 420 Sovereign so they should be the same parts for your S type.
Dovetail plate screw - BD16940/2 - 12 off per car (superseded by BD15534/3)
Striker plate screw - BD21590/7 - 12 off per car
Hinge to door screw - 1490 - 12 off per car
Hinge to A post screw - 6784 - 4 off per car
Hinge to A post screw - 6785 - 8 off per car
I am sure all the main Jag specialist will have them. I have checked the David Manners site and they list them all.
If you are hoping to get them from alternative hardware suppliers then I don't know the specifications for them. Presumably, they are chrome plated so not as easy to come by as standard finish items.
Hope this helps you in some way.
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
1962 E-Type FHC
1994 X300 XJR
blackbeltuk
Stuart.
Thanks for the info. Door hinge bolts have been ordered.
Ricky,
Ricky,
Users browsing this forum: No registered users and 16 guests
