radio change
bryan13
radio change
Postby bryan13 » Thu Oct 09, 2014 8:53 am
advice needed, my radio/CD player display wouldn't light up unless really cold, so i thought i would change it instead of repair, got a second hand one and fitted it but now my Bluetooth wont work just displays no phone and my rear parking sensors beep constant when you select reverse, my radio date is a 05 and the one i fitted is a 04 would there be a compatibility problem between the two or some thing i have done.
thanks Bryan
2005 s type 2.7 diesel Se by far best so far
2001 x type 2.5 petrol sport
L reg xj sov 4.0
F reg xj sov 3.6
a reg xjs v12
Re: radio change
Postby J44EAG » Fri Oct 10, 2014 4:45 pm
As a general rule, with any electronic part or model, it must be replaced with a unit that bears exactly the same serial number which may start XR8, C2Z etc.
There are a large number of part number changes over the years for S-type and other models. If buying aftermarket parts, it is again imperative to buy accurately cross referencing parts before committing to buy.
bryan13
Re: radio change
Postby bryan13 » Mon Oct 13, 2014 4:51 pm
Hi Mike both units have same numbers reverse beeper has settled down now and working but still only getting no phone message on audio screen so i am guessing i have upset the Bluetooth module or something tried disconnecting the battery for a while and reconnecting still no luck will keep looking Bryan
L reg xj sov 4.0
F reg xj sov 3.6
a reg xjs v12
Montana5
Re: radio change
Postby Montana5 » Tue Oct 14, 2014 11:11 am
Did you pair the phone again after fitting the new radio and connecting up, I reckon a complete disconnect like that would have the module thinking its a new installation.
Doug.
S Type Forum Moderator
bryan13
Re: radio change
Postby bryan13 » Tue Oct 14, 2014 3:19 pm
Hi Doug
the problem is it wont let me unless im doing something wrong i turn the stereo on press the left hand phone button the screen displays no phone i try and enter the code and nothing happens it just goes to the radio display if i use the scan setting on my phone it wont pick up a signal from jaguar at all i will have another read of the manual and make sure im not missing a step
Bryan
L reg xj sov 4.0
F reg xj sov 3.6
a reg xjs v12
andypryce
Re: radio change
Postby andypryce » Wed Oct 15, 2014 10:14 pm
I would agree with Doug, if you are getting the phone screen and it's saying phone not connected, you need to start from scratch and pair it again, as per the manual. If you dont have the steps for pairing post again and will put them on here, as the procedure for the XJ and the S type is exactly the same.
XF Sportbrake 2020 / XK8 1998
bryan13
Re: radio change
Postby bryan13 » Sat Oct 18, 2014 11:20 am
Hi Andy
tried entering the code with radio on and off still not accepting, it just states no phone if you can post the procedure i will check im doing it correct its the system without nav screen
Ta Bryan
L reg xj sov 4.0
F reg xj sov 3.6
a reg xjs v12
andypryce
Re: radio change
Postby andypryce » Sat Oct 18, 2014 5:19 pm
Ah, in that case not sure, the system on my previous S type and current XJ has the sat nav screen, so it will be different, I am sure someone out there has it though? Apologies.
andy
