Road Marking paint spray on rear bumper
BigCatXJS
Postby BigCatXJS » Sun Sep 21, 2014 10:30 pm
So recently there has been some road works on the A14 and a local road where a new housing estate is being prepared. Cleaning the wheels etc for a show today, I noticed some white paint spots on my rear wing, boot lid, and rear bumper sections. Although I have removed most of the white spots from the paint work, the spots on the rear bumper section wont shift easily without scarring the bumper or leaving a rub mark :(
Any tips for removing without inflicting any damage?
Thanks, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
dhdove
Re: Road Marking paint spray on rear bumper
Postby dhdove » Mon Sep 22, 2014 3:57 am
Clay bar?
TonyS
XJS Bulletin Board Moderator
Postby ptjs1 » Mon Sep 22, 2014 7:44 am
Rich,
Sorry to hear this. I think I would try the following order:
- Waterless Wash Spray
- Farecla G3 cutting paste
- 1200 Wet and Dry
Postby J44EAG » Mon Sep 22, 2014 9:59 am
Ideally the solvent originally used in the road paint would help. That would revitalise and soften the paint and allow it to be broken up with a solvent soaked rag.
The question is, what is that solvent? You could start with white spirit, acetone. zylene and perhaps go onto a proprietary tar and gum remover sold at most accessory shops. Tar and gum remover shifts all sorts of road type contaminates. Obviously go easy with it initially to ensure it does not attack paintwork.
BigCatXJS
Postby BigCatXJS » Mon Sep 22, 2014 10:04 am
Thanks for all the suggestions guys.
Will these be okay to use on the bumper surface?
Mine's the black pre-facelift non-painted black bumper.
I have tried pro-shine waterless wash on the bumper before, but this can fade the colour somewhat, especially with intensive rubbing.
Ta, Rich
Past:
1985 E28 BMW M535
Postby Brakebuster » Mon Sep 22, 2014 12:19 pm
most road marking isnt actually ' piant ' its hot plastic , which is why it smells bad when you drive past them doing it
i would try the clay bar first, if really bad try some panel wipe as used for paint prep , you will be surprised at how well that works on most things
and its totally neutral towards all plastics and paint , but will leave it needing a polish , as you will strip away all contanimants on top of the surface
after that is very carefull use of a very sharp knife blade and ' pick ' then off
its how the bodyshops do it
BigCatXJS
Postby BigCatXJS » Mon Oct 06, 2014 1:44 pm
Update:
Clay-bricked twice - did not touch it (but did remove other deposits).
Tried some cutting paste - again, no luck
Ended-up polishing with some black interior polish spray. You can still see the white spots but at least it is less obvious.
Shark knife helped with some spots on the paintwork, but started scarring the bumper so gave up on that!
Cheers, Rich
Past:
1985 E28 BMW M535
Postby J44EAG » Mon Oct 06, 2014 5:10 pm
Have you tried a very sharp chisel used flat? Go easy and paint can be buffed up again.
Postby Brakebuster » Mon Oct 06, 2014 6:05 pm
body-shop top tip
craft knife blade with a couple of wraps of masking tape over the sharp edge on each side of the middle, this will lift it off the paintwork by 0.25mm and will stop the blade actually touching the paint , then drawing the blade over the surface only the masking tape will touch the paint , and the exposed blade will reduce the debris on the surface ,
the scraped down debris will be easier to remove by other methods or solvents etc
Postby J44EAG » Mon Oct 06, 2014 8:17 pm
Been car body bashing and paint refinishing for years, Vince. Not heard that tip before. Nice one. Dead cute. I like it.
BigCatXJS
Postby BigCatXJS » Tue Oct 07, 2014 9:58 am
Thanks guys.
Unfortunately these paint marks are quite small; the largest is around 1mm across. My bumpers are the black plastic pre-facelift, so there is no paint on them. Certainly the sharp knife helped remove all the paint spots on the paintwork (rear wing and boot lid) no problem. I'm concerned that solvents will discolour the black plastic further. I think I've already taken some colour out by using some cutting paste.
Cheers, Rich
Past:
1985 E28 BMW M535
PaulGover
Postby PaulGover » Wed Oct 08, 2014 2:17 pm
I found Jizer (or maybe Jizzer) can shift butyl rubber, which is completely different, but it might be worth a try, and anyway it's useful for general engine cleaning.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
Users browsing this forum: No registered users and 16 guests
