first of all , the windscreen washers didn't work , but the pump was running, a quick disassemble of the washers them selves, clean out and prime the system , and voila , clean windscreen again
then onto the reverse sensors, just getting a beep on ignition turnover , had a rear bumper repair a few months back , and thought it might be something to do with that, found both outboard sensors had a broken wire going to the plug, crimped them back together, weatherproofed , and voila , beep beep beep when going backwards
the passenger door rubbing strip had decided to come unglued, tried several things in the past, but decided today to take off the inner panel , and put a stainless self tapping screw into the trim from inside the door , voila , no more flappy flappy door trim
then the headlight on the passenger side had decided not to come out to play , you need the hands of a thin thing with thin hands , not like mine, but some swearing later, and a new lamp , voila , can now see in the dark ( well almost )
and then a trip to ProTyre for 4 brand new Pirelli P7 tyres ( not bad for £275 all in )
voila.....erm,,,,,,,voila
