308 bumper height
Moderators:robv12, DavidEm
steveandtina
308 bumper height
Postby steveandtina » Sat Jul 20, 2013 10:07 am
Anyone know how the rear bumper on 308s is adjusted." Mine sags v/ slightly on near side and was wondering if there is any way it can be moved. Thanks Steve!
Re: 308 bumper height
Postby Brakebuster » Mon Jul 22, 2013 2:07 pm
your ' sagging ' bumper will be the result of a broken bumper mount on that side, you need to take off the chrome, this will give access to the fixing/adjusting bolt
the issue is the adjusting bolt and the mount are differing metals and corrode badly , then when trying to adjust the bolt breaks off , giving a sagging bumper, and it probably moves up and down as well
only real fix is to remove the bumper and install new mounts, about £40 each , and you will need two of them ,
then when the bumper is put back on you can make it fit perfectly
steveandtina
Postby steveandtina » Mon Jul 29, 2013 11:54 am
All bolts etc covered thick in waxoyle can't see them bieng corroded its been like this a long time just need to know how they adjust, it's only slight and no play in bumper at all
