simple enough operation which required jacking the car up safely and securely on axle stands, sliding under the car, identifying the existing mustard coloured Holley branded modulator and removing the retaining bracket thats held in with a half inch bolt ,
the modulator simply extracts with a ' pop ' as the seal is broken from the O ring , with very little gearbox oil dripping from the aperture ,
the existing vacuum hose was hard , though not perished, but i bought a new one anyway ,
the new modulator is significantly smaller than the original Holley unit and is finished in an electroplate effect, but is still made in the USA , and is a perfect fit ,
installation was to simply push back into the gearbox , ensure a snug fit and then offer up the retaining bracket and tighten down the bolt ,
Replacing the vacuum hose is easy enough , but made easier by attaching to the old hose under the car, and then pulling through to the top of the engine from above, this is fitted to the back of the right bank inlet plenum , where two other hoses are fitted ,
with all the installation completed i now have to take her for a test drive to ensure everything is working fine,
i have retained al the original parts......just in case
the reason behind the change is that my unit is 24 years old, and the car has done 105k miles , and for the small cost i feel it was worth the effort, and the vacuum diaphragm is known to get weak and slightly alter the gear changing point compared to engine load
