Gearbox insulator mount disintigrated?
Postby J44EAG » Sat Jun 29, 2013 8:25 pm
J44EAG is now eleven years old and has 86k miles under its belt. It has been tweaked and driven very hard whilst in my hands.
The car has reached the age when parts fail with regular monotony. The early models are well known for rather patchy build quality and many electrical issues. Later cars are generally rather more reliable.
My car blew a gearbox at 54k miles and was reconditioned successfully. I`m unsure whether the gearbox mount was changed at the time.
Recently J44 started to exhibit minor vibration when accelerating away from a junction. This appeared to come from the transmission tunnel just aft of the gear selector.
Yesterday on my run from Portsmouth to Caterham, I noticed an increased level of general vibration. Today on a run to North Weald, accelerating hard up a hill in Brentford, a distinct drumming and banging was heard and felt. Perhaps confirmation that a gearbox mount has disintegrated. I`ve yet to confirm a failure by inspection. Otherwise I`d plump for propshaft issue. Cost of the insulator mount would appear to be round £20. Early five speed V6 and V8 models share the same part but am unsure if the part was carried forward onto later derivatives.
Has anyone else experience a similar fault? Comments appreciated.
Poor old J44 is falling to bits. This afternoon the front trim thing fell off the coin tray. Most odd that. I`ve never even used the facility let alone even opened the draw! In fact I`ve never laid a hand on it!!! Early cars certainly become flimsy when they age.Thank goodness for double sited number plate tape.J44 is held together with the stuff.
oldtimer
Re: Gearbox insulator mount disintigrated?
Postby oldtimer » Sat Jun 29, 2013 10:13 pm
Gordon Bennett, you're having a bad time with J44 at the moment, about time you gave that boat a rest and gave the old gal a bit of attention!
Phli
Postby J44EAG » Sun Jun 30, 2013 9:06 am
Its old age and use, Phil.
Modern parts either work and are serviceable or they are broken. There is little or nothing in between!
The best thing I can do is pick up a gearbox insulator at Harwoods in Chichester on the way home tomorrow and have my friend John at Jagcare in Portsmouth fit it for me on his ramp. That will save me having to find a way of getting the car up in the air in the boatyard and having to crawl around underneath on my back like an out of work Wren.
As a car ages, it becomes like a patchwork quilt. Patches upon patches upon patches. Re-life on part and another hole appears elsewhere.
J44 is now an old car. I have to look at the car as a whole before I spend money to keep it going. Value is only around £1000 now so I now apply a minimal expenditure rule as to what can justifiably be spent on such an aged vehicle.
Postby J44EAG » Wed Jul 03, 2013 10:06 am
Broken J44 now fixed again.
Every picture tells a story.
Not as I surmised, a nacked gearbox cross member or insulator mount, but the gearbox output to propshaft doughnut. Absolutely shot! Seriously on its last legs but not itemized at the MOT last December.
Good secondhand unit fitted for £40 all in. Good old Jagcare. Highly recommended.
Bolts found to be not as tight as they could have been. Unit had been winding up under load and bright witness marks seen on the through bolt washers.
So all fixed up again and rather smoother to drive. Well pleased.
