pre he man xjs
dougie
pre he man xjs
Postby dougie » Fri Dec 07, 2012 6:32 pm
I am in the process of carrying out a med resto on a 1977 4-spd XJS and am looking for any pre-he parts or a complete scrap car. I will be asking lots of pre he questions in the coming weeks
text me 07803922945
Re: pre he man xjs
Postby Brakebuster » Fri Dec 07, 2012 6:46 pm
good on ya 8)
got any pics ?
i have just finished a full resto project on an 89 HE
i have several body panels going spare at the moment, like a full rear quarter for the drivers side, a rear bootlid skin with separate internal frame section , and two full length sill repair sections as well ad a drivers door outer skin , all panels are new , a few fillets and strengthening panels to
also have a V12 inlet manifold with four carbs and air injection , from an E-type, but will fit any V12
kelsham
Re: pre he man xjs
Postby kelsham » Sat Dec 08, 2012 5:49 pm
I have a distributor, petrol tank and one or two more bits lying around. What are you after?
Regards Kels.
dougie
Re: pre he man xjs
Postby dougie » Sun Dec 09, 2012 12:39 am
Would you believe i dont need any major body panels but i do have to repair the n/s/f jacking point. I need both speedo angle drives, headlights, alternator, clutch hose, rear hyd calipers and any ignition bit to have as spares. At the mo i dont need any major stuff, but would be happy to buy any easy to post stuff.
dougie
Re: pre he man xjs
Postby dougie » Mon Dec 17, 2012 9:16 pm
got 2 Pre He`s now
BigCatXJS
Re: pre he man xjs
Postby BigCatXJS » Tue Dec 18, 2012 10:37 am
Nice!
There is this one at Clarkes of Sussex...
Not sure about the twin headlight conversion on a pre-he, but nowt wrong with Signal Red.
Very pretty, tidy car....
dougie
Re: pre he man xjs
Postby dougie » Mon Mar 25, 2013 10:37 pm
Well, the med resto has grown arms and legs into an almost major resto. So far on the body i have replaced both lower rear 1/4`s, patched the rear panel and round the tailights, cut out and replaced all the bad metal inside the n/s/r rad arm mount and chassis leg,repaired inner sills at rear but oddly the o/s mount was like new inside. Replaced most of the n/s/r inner wheel arch. All Jag panels. had to replace the n/s/f jacking point and most of the surrounding metal.Front crossmember and legs like new and floorpans just needed and wash and brush up.
Aquired a gen jag unpainted bootlid for £100 from Manners (they have one other left)and also a n/s/r wing.Good doors from spares car. But worst bit is the car had a sunroof fitted which someone has removed and welded in a plate and what a balls up but skinned up not bad with about an ton of filler, so i am going to have to really test the old skills by fitting a new (secondhand) roofskin.Windscreen surround ok but screen badly chipped and cracked at the slightest pressure.Also needs a new headlining.
Mechanically not too bad. Found vac advance bust, so dizzy out and a check of the weights and a gen tidy up and back in. Surprised to find it is still on the 3-wire trigger board. All new belts and new alternator.Had to make one aux air valve from two but got a working one now New front discs and got a cracking deal and 4 recon calipers (£150 for 4) new pads,pipes,hoses, rear shockers and hand brake pads. Radius arm bushes,steering rack bushes and gearbox mount bush (what a faff that was for what it is) lower and upper speedo boxes and a working pre he speedo with some mileage correction (not done that for a while, soon came back to me though) to same as previous one but no idea of true mileage, still has BL exhaust in not bad cond and managed to pick up a pair of gen back boxes.
Hopefully off to the bodyshop tomorrow for the last of the fussy bodystuff and we will do roofskin and n/s rear wing up there.I will get the covers off the bumpers and get them fitting better also have a go at cleaning seats whilst garage is empty but suspect they will need the attention of an upholsterer who will no doubt throw up his arms at the mess ive made but that may have to wait till next winter. The car has flattened my wallet enough this year.
So far not had anything too difficult just sometimes frustrating but thank goodness i can do most stuff myself and have some good mates rates with body guys and favours to call in with the local motor factors or i would be into £000`s and who knows in labour alone. But doing an XJS in a 17`x 10` single garage with the door shut to keep the heat in has called for a bit of advance planning but i have strong joists so the block and tackle slung round bumper mounts replaced the trolley jack. Also handy when replacing rear cradle.
The spares pre he has not been the god send i hoped. It is more knackerd than mine but engine and electronic bits are fine.
Hopefully going to have a Yellow Gold 4-speeder at the steam in the park weekend in May.
BigCatXJS
Re: pre he man xjs
Postby BigCatXJS » Tue Mar 26, 2013 10:12 am
Crikey! That sounds like a project!
Any pics?
dougie
Re: pre he man xjs
Postby dougie » Wed Mar 27, 2013 7:42 pm
no i havent any pics. But the car is off to the bodyshop on time. I will try and get a pic of the roofskin off
dougie
Re: pre he man xjs
Postby dougie » Sun Apr 21, 2013 11:31 pm
some pics
dougie
Re: pre he man xjs
Postby dougie » Sun Apr 21, 2013 11:36 pm
another. roof panel swap not too bad a job. Interior now out for a clean and bumpers and wheels alos to get a bit of spit and polish. Passenger door saveable but drivers door frame is shot but i have another pre he door that is fine. New window and door rubbers and headlining ordered and that is it. The wallet is bust, anything else will have to wait.
dougie
Re: pre he man xjs
Postby dougie » Sun Jun 09, 2013 8:22 pm
All finito and hopefully off for the test on Weds. its lookin the dugs ba`s
Re: pre he man xjs
Postby ptjs1 » Mon Jun 10, 2013 12:35 pm
Well done Dougie!
Sounds like a great candidate for an article for the magazine?
dougie
Re: pre he man xjs
Postby dougie » Mon Jun 10, 2013 10:52 pm
the only photo as battery went flat
dougie
Re: pre he man xjs
Postby dougie » Sun Jun 16, 2013 9:34 pm
Passed mot and now in use but having a bit of bother with hesitation on acc unless fit is to the carpet and the wallet cant keep up with that. So changed fuel filter,plugs(with were all nice and beige with a darker ring on outsite,lovely, all 12 at that) and had a go to get the timing sorted but lost the timing marks so a bit of guesswork was done, running a lot better but i noticed the throttle bushes are missing on l/h bank. The bloody fuel guage packed up on me so a couple of gallons in the boot till i get a chance to sort it.
some photy`s below
