Fault codes
Moderators:robv12, DavidEm
venge
Fault codes
Postby venge » Sun Mar 10, 2013 8:54 pm
Before I begin may I explain that I am the least technically minded person on Earth and therefore would appreciate any response in leymans terms.
I have a 2000 X308 3.2 V8 that has been running a tad rough lately so I purchased a code reader which upon testing the car has shown up 2 faults. The first states 'Ignition coil H primary/secondary circuit malfunction'. I am aware this looks like a coil that needs replacing but my first question is, how do I find out which coil is 'H' and are they easy to change?
Secondly 'Linear 02 sensor control chip (bank 1)' not sure what that is or where I would find it.
Any help in locating the two points would be greatly appreciated.
Phil :?:
2004 X350 3.0 V6
Re: Fault codes
Postby Brakebuster » Sun Mar 10, 2013 9:54 pm
coil H should be the nearest to the windscreen on the passenger side,
as they are A-H front right to back left as your sat in the car
the O2 sensor , is the lambda sensor on the exhaust , drivers side, second sensor downstream
Re: Fault codes
Postby Brakebuster » Sun Mar 10, 2013 9:56 pm
i would change the coil first, as this may be upsetting the ECU and the exhaust , even though the injector for that cylinder is electronically shut off ,
you will need a four ( 4 ) pin coil for your car , not the 2 pin version
replacing the coil may negate the O2 sensor fault
BB 8)
venge
Re: Fault codes
Postby venge » Sun Mar 10, 2013 10:23 pm
Hey Thanks BB, much appreciated mate.
2004 X350 3.0 V6
