Water leak
Welcome to the JEC forums
it may well be the screen ,
but you may also want to check a place by the bonnet resting bolts on the windscreen scuttle, these have small rubber tops on the bolts a few inches from the windscreen wipers, the reason for this is the scuttle can rot out in this area,
also the aircon system may be leaking into the passenger footwell , its not aircon as such , but condensate from the cooling action
and finally , the heater matrix, make sure the coolant level isnt dropping for this one
hope you get it sorted
Re: Water leak
It would seem that the previous owner was unaware of the problem so did not attempt a remedy
I think it more likely that he was very aware of the problem which is why it was for sale
However, no 12 year old car whatever make or model will be free of problems, so at least you are among friends who will guide you along.
Pop
Pop
