In the coming weeks I will be removing my complete front suspension for refurb which looks pretty straight forward apart from one thing
There is a V shaped mount on either side, how are these connected to the body / which way up are they / are they easy to access. As the car is covered up at the moment and I can't see the area
Any help much apprciated
Richard
XJ S1 Complete Front Suspension Removal
Moderator:LJR
Re: XJ S1 Complete Front Suspension Removal
The rear mounts of the front cross beam (if that's what we're talking about) are attached to the chassis rail by two bolts and to the cross member by a stud. If the engine is out, they are quite simple to get at. If it is still in things are a bit more restricted.
I found getting the front mounts off was the biggest challenge: the sleeve inside the rubber bush had rust welded itself to the large bolt.
Al McL
richardpierce
Exactly what I needed to know, much appreciated almcl
Richard
Richard
Hi Richard and Al Mc,
My job for the Spring. While I am changing the steering rack and have the access shall change both mounts.Not looking forward to the job but needs doing, after forty years they both look a bit weather beaten.
Problem is I aint taking the engine out so will have to support it. Pity the engine sits on the cross member.
Oldtimer
Oldtimer
richardpierce
Enjoy old timer!
Luckily my engine is out
Richard
Richard
