I double checked the JTIS procedure and at no point does it mention the need to remove an engine block drain plug, although there is mention elsewhere that a drain plug exists at the rear of the cylinder block behind the starter motor. At no point does the procedure refer to removal of this plug, however unless there is some sort of syphoning action, I can't see how else the engine block would drain down
I tried to locate this drain plug, but unfortunately the limited clearance under the vehicle meant my eyes could not focus sufficiently to see clearly what I was looking at. (Oh to be a young buck again
Can anyone confirm for me whether it is indeed necessary to open the engine drain plug, and if so, provide me with tips for locating and removing this plug easily. If plug removal is not necessary, does anyone have a clue where I might be going wrong and perhaps provide me with the correct procedure
