front suspension bushes
chrisdaren
Postby chrisdaren » Sat Jun 19, 2010 8:26 pm
hi has anybody change top bushes if so how would do it any idears thanks chris daren :roll:
robv12
Re: front suspension bushes
Postby robv12 » Sat Apr 28, 2012 5:43 pm
shocker bushes or wishbone bushes??
jBlackwell
Site Admin
Postby jBlackwell » Tue May 01, 2012 8:17 am
Im about to replace, upper wishbone bushes and top bushes on shock absorbers. Feeling in the dark a bit myself.
James
XjRestorations
Postby XjRestorations » Tue May 01, 2012 12:36 pm
The upper wishbone bushes are nice and easy - no special tools required :-)
With the car raised at the front, remove the two 3/8 bolts that go through the top wishbones and ball joint. The damper will already be at full stretch and will hold the lower wishbone and spring all together.
The hub will now fall forward (as there is no ball joint holding it in place).
Undo the upper wishbone nut and draw the upper fulcrum bolt out of the wishbone/cage assembly. On the passener side, there is a cannister that needs to be unbolted to allow the fulcrum to pass by (3 fixing bolts from memory).
Remove both wishbones. Burn/cut/press ou the old bushes - press in new bushes and then reverse the above to refit :-)
Hope this helps - any queries, drop me a line :-)
Keith
jBlackwell
Site Admin
Postby jBlackwell » Tue May 01, 2012 4:25 pm
Cheers Keith,
So I don't need to compress the spring, the lower wishbone will take all that tension out?
Excellent advice as always :)
James
XjRestorations
Postby XjRestorations » Wed May 02, 2012 10:35 am
Hi James,
No spring compressor needed here :-)
Always happy to help.
